Old 07-09-2015, 05:26 AM   #1
SunnyDay
Drives: 86
Is it possible to add shift paddles to the GT?
Hi,
I have an automatic 86 GT (not GTS) that came with no shift paddles. Is it possible to add them to the steering wheel? Does anyone know if the wiring is in the steering wheel and ready to be connected the paddles?
Any insights more than welcome!
Thanks
SunnyDay is offline   Reply With Quote
Old 07-09-2015, 05:53 AM   #2
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Given that this forum is U.S. centric and the gt86 isn't available there I would suggest calling Toyota Australia and asking them though I do not like the chances of anyone there knowing the answer to your question.
Old 07-09-2015, 07:03 AM   #3
SUB-FT86
86 Member
Drives: 2013 Toyota 86 2.0T (Asphalt)
Why would a sports car after 2013 come without the paddles? Toyota/Suabru is so wrong for that. That would've been a deal breaker for me as I prefer paddles over the console stick. I feel more focus with the paddles.
SUB-FT86 is offline   Reply With Quote
Old 07-09-2015, 08:50 AM   #4
Captain Snooze
Drives: Red Herring
It is not "wrong"; it is marketing. There is about a $6000 difference between the two models here. It allows Toyota to upsell the GTS having more features. "Yes sir, the GTS also has paddle-shift which the base model doesn't have." If the paddles are a deal breaker but you still want the car then you fork over the extra cash.
Dream20b (07-09-2015)
Old 07-09-2015, 09:15 AM   #5
evomike
Drives: frs
honestly anything with a torque converter and paddles is pointless to me
evomike is offline   Reply With Quote
The Following 3 Users Say Thank You to evomike For This Useful Post:
Dream20b (07-09-2015), Summerwolf (07-09-2015), woode (07-09-2015)
Old 07-09-2015, 09:31 AM   #6
Captain Snooze
Drives: Red Herring
Thanks for sharing but it doesn't help op.
Valentino (07-14-2015)
Old 07-09-2015, 12:47 PM   #7
KoolBRZ
KoolBRZ's Avatar
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
I'd be willing to bet they plug right in. You might need to use techstream to make them functional. You'd probably need the other steering column housing as well.
KoolBRZ is offline   Reply With Quote
Old 07-09-2015, 04:23 PM   #8
SUB-FT86
86 Member
If our cars were a typical GT sedan/coupe I could understand that fully. Like paddles are optional with the S package on a Q50 sedan for instance. But it's not a sports car so it's no big deal. The FRS is a ground up sports car.
Old 07-09-2015, 09:29 PM   #9
KoolBRZ
KoolBRZ's Avatar
It's RWD, so either it's a sportscar, or a pickup. Now FWD cars aren't real sportscars, because they can't drift.
Old 07-09-2015, 09:36 PM   #10
Wow! I am glad to know I drove nothing but sports cars for 30 years.
Police may be surprised that they drive them though.
Yet another oversimplification brought to you by KoolBRZ.
Bergen23 (07-18-2015), soulreapersteve (07-09-2015), woode (07-09-2015)
Old 07-09-2015, 10:00 PM   #11
Oh and...
Captain Snooze (07-09-2015)
Old 07-09-2015, 10:12 PM   #12
Originally Posted by SunnyDay View Post
Hi,
Thanks
So back on topic.
I could not find any info that says it is or isn't possible but strongly doubt even if possible would cost a pile of cash. To buy the parts and retrofit everything would certainly not be a cheap proposition. You would also need to be able to flash the ECU and tranny module (TCU?) to be able to control the shifts.
Old 07-09-2015, 11:51 PM   #13
SteveIsBored
Drives: 2013 subaru brz
You would probably need the steering wheel, the body wire harness, and the trans module to make it work, as long as the two transmissions are the same
SteveIsBored is offline   Reply With Quote
Old 07-10-2015, 12:25 AM   #14
KoolBRZ
KoolBRZ's Avatar
Just get an entire steering wheel and column from a wrecking yard, a cheap ebay cable with a (cracked) copy of techstream, and install, connect up with the techstream cable, find where it's at and check the box for shift paddles "yes".
paddle-shifters
SOLD: carbing shift knob infocus shift boot digital camo toby714 Interior Parts (Incl. Lighting) 6 07-02-2015 10:33 PM
FS: WeatherTech Mats/Shift Knob/Shift Boot/Sunshade (WI) wgnzlz Interior Parts (Incl. Lighting) 8 06-09-2014 10:36 PM
CF Shift Paddles? FRS_Ken Cosmetic Modification (Interior/Exterior/Lighting) 2 01-24-2013 12:05 AM
I know the automatic has paddles, but..... Jedi1 Engine, Exhaust, Transmission 34 10-02-2012 02:50 PM
