Drives: whiteout 2014 Scion FR-S
Turn signals running lights
Hello all, about three months ago I installed switchback led turn signals that I purchased from Diode Dynamics. My right led bulb burned out prematurely , so I reinstalled the factory halogen bulbs. They work as turn signals, but neither bulb stays on continuously when I turn on my lights or low beams as they did before installing the LEDs. Does anyone know what may be causing this?
Thanks |
#2 |
Drives: 2014 Argento FRS
Did you only reinstall the right side with a halogen bulb? Meaning you're running led on driver side and halogen on passenger?
#3 |
No, I reinstalled the halogen bulbs on both sides.
#4 |
Drives: 2013 Firestorm
Replace the flasher module?
#5 |
I replaced my flasher module to fix hyper link when I rewired my tail lights to use the brake lights as turn signals, which was long before I installed the front led signals. So I currently have that same module installed. I also have the winjet headlights with the led running lights. Would that override the turn signals?
| any FR-Ss running yellow/gold turn signals? | BlueDubbinTDI | Cosmetic Modification (Interior/Exterior/Lighting) | 12 | 12-17-2013 12:02 PM |
| DIY JWMotoring LED turn signals | sirhc | DIY (Do-It-Yourself) Guides | 54 | 03-16-2013 04:22 PM |
| Custom turn signals? | benlevy3 | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 11-01-2012 04:23 PM |
| Need help with LED turn signals. | Khalis | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 08-12-2012 12:23 AM |
