Old 05-15-2013, 01:21 PM   #1
Kuzuri
__(X)__
Kuzuri's Avatar
Drives: '11 Legacy, '89 190E, '78 GS1000
Removing rear brake rotors?
I recently put some new wheels on my car and I want to run 10mm spacers and I have a pair with extended studs... Im having some trouble getting the rear rotors off though... Its been a while since ive done this... but last time I did it was on my tC which was FWD...
is there anything different? or would I just have to adjust the ebrake tension thing and then use a mallet to get the rotor off?
Thanks!
IG: @dustin_faulkner
Kuzuri is offline   Reply With Quote
Old 05-15-2013, 01:27 PM   #2
OrbitalEllipses
Drives: Attitude
Make sure parking brake is off. Rotor may be seized to the hub; lightly tap the inboard side of the rotor with a rubber mallet at equidistant points. There should also be two threaded holes in the rotor hat that you can insert a bolt into in order to break the hat free of the hub.
whataboutbob (07-18-2015)
Old 05-16-2013, 12:31 AM   #3
JimmyMac
JimmyMac's Avatar
Drives: 2013 FR-S, 2016 Miata Club
Maybe it's too late but...
http://www.ft86club.com/forums/showt...ar+brake+rotor
JimmyMac is offline   Reply With Quote
Old 07-18-2015, 08:54 PM   #4
chris912
chris912's Avatar
Drives: 2013 Firestorm 6MT FR-S
Sorry to revive a dead thread, but does anyone here know what size bolts go into the threaded holes in the rotor?
chris912 is offline   Reply With Quote
The Following User Says Thank You to chris912 For This Useful Post:
XtremeMaC (04-28-2019)
Old 07-18-2015, 10:08 PM   #5
Fishbone
Drives: 2024 GR86
M8 X 1.25 Bolt
IIRC
Fishbone is offline   Reply With Quote
The Following 3 Users Say Thank You to Fishbone For This Useful Post:
Andyxin (05-19-2018), chris912 (07-18-2015), XtremeMaC (04-28-2019)
Brake Pads, Rotors and All Your Brake/Suspension Needs! Great Prices!! Check it out!! Mike@CZP Brakes, Suspension, Chassis 348 06-01-2018 01:29 PM
BBK,BRAKE PAD,BRAKE ROTORS,MASTER CYLINDER BRACE +MORE @ Source,LLC SOURCE,LLC Brakes, Suspension, Chassis 94 07-07-2013 11:56 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 11:20 PM
Help Removing Rear Seats and Rear Part of Center Console ZC6BRZ Cosmetic Modification (Interior/Exterior/Lighting) 2 08-27-2012 04:11 PM
StopTech Slotted Brake Rotors (Front/Rear) for BRZ/FRS at Redline360 Redline360 Brakes, Suspension, Chassis 0 07-13-2012 11:58 AM
