Old 07-06-2012, 11:31 PM   #1
Lowellrenzo
Drives: Civic Si coupe
shifting and down shifting feel
Anybody feel the rough
ness?
Lowellrenzo is offline   Reply With Quote
Old 07-06-2012, 11:33 PM   #2
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
no your doing something wrong. I can shift up and you cant feel it. Same with downshifting, just need to practice more.
WolfsFang is offline   Reply With Quote
The Following User Says Thank You to WolfsFang For This Useful Post:
FTEIGHTSIX (07-08-2012)
Old 07-06-2012, 11:51 PM   #3
imravenit
give us this day
imravenit's Avatar
Drives: AE86 - FRS
i have to admit its a lil tough and notchy but i can understand its still new i only have 50miles on it so imma let it loosen up
imravenit is offline   Reply With Quote
Old 07-07-2012, 12:38 AM   #4
ahausheer
Re-member
Drives: Toyota camry
It should loosen up on ya as it breaks in more and more. Unless you got a genuine issue. Transmissions literally shave metal off themselves for a while until its fully broken in. If you have ever changed the transmission filter and fluid on a car that has some miles on it you will see the transmission magnets are coated with metallic shavings that can be large enough to feel gritty. I recently found a small metallic splinter in one transmission pan and it stuck in my hand. And that was from an auto transmission that shifts perfectly. Case in point, the transmissions often needs time to break in. Hence the break in period.
Nothing decays like progress, and nothing preserves like neglect.
ahausheer is offline   Reply With Quote
Old 07-07-2012, 12:43 AM   #5
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
the position of the clutch doesn't help .. also how light it is.
just give it a few miles, get used to this clutch :/
Old 07-07-2012, 12:47 AM   #6
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Do you mean the clunky noise from the rear differential?
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Old 07-07-2012, 01:51 AM   #7
Chewie4299
Spaceman
Chewie4299's Avatar
Drives: 2013 Firestorm Scion FR-S
Tis normal
Chewie4299 is offline   Reply With Quote
Old 07-07-2012, 01:59 AM   #8
Billy2224
Professional Racer
Billy2224's Avatar
Drives: Supra, Cooper S, GT86, Formula 3
i wish that clunk when you shift into 1st happened every time you changed gear. AWESOME, feels better than the clunk from the Audi R8 tranny
Billy2224 is offline   Reply With Quote
Old 07-07-2012, 02:00 AM   #9
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Originally Posted by Chewie4299 View Post
Tis normal
Yep, I just wasn't sure if the OP was aware (if that was even the noise he meant).
Old 07-07-2012, 02:42 AM   #10
Pscylo
Pscylo's Avatar
Drives: Raven FR-S
I get looks in the parking lot leaving work when I roll around in first and the press the clutch to stop at all the stop signs and cross walks....because of that clunk.....makes me want to hang my head out the window and go - "Yes, I know how to drive a stick, and yes that is normal."
Pscylo is offline   Reply With Quote
The Following User Says Thank You to Pscylo For This Useful Post:
Linseal (07-07-2012)
Old 07-07-2012, 03:01 AM   #11
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
all the more reason to actually stop at stop signs!
Old 07-07-2012, 08:22 AM   #12
SportInjected
SportInjected's Avatar
Drives: for the sake of driving
Tis normal
That's good to know. I was starting to get slightly concerned when it didn't go away after 500 miles.
'13 Argento FR-S
SportInjected is offline   Reply With Quote
Old 07-07-2012, 01:41 PM   #13
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Subaru designed and made :]
Super loud trans hahaha
- I think
The Following User Says Thank You to Bonburner For This Useful Post:
blu_ (07-08-2012)
Old 07-07-2012, 02:26 PM   #14
WolfsFang
Scrape Master
WolfsFang's Avatar
Does anyone get a clink when they put it into first? Sometimes mt car moves like a inch when I put it in first.
Sent from my DROID X2 using Tapatalk 2
You do realize comparing the BRZ to the FR-S is like comparing which hand you love masterbating too right?
Hard shifting into first gear; normal? blalor Engine, Exhaust, Transmission 54 08-31-2017 10:57 PM
shifting from 1st to 2nd jarviz Scion FR-S / Toyota 86 GT86 General Forum 35 05-26-2016 08:15 PM
Hard shifting into 2nd gear when cold BMWDavid BRZ First-Gen (2012+) — General Topics 35 06-24-2012 03:22 PM
Thud/Clunk when shifting. erom Engine, Exhaust, Transmission 10 06-17-2012 08:08 PM
How's the shifting of MT compared to other cars Lowellrenzo Scion FR-S / Toyota 86 GT86 General Forum 25 06-07-2012 11:20 AM
