Old 06-18-2012, 11:47 PM   #1
kmbkk
First 86 Driver Baby!
kmbkk's Avatar
Drives: FR-S, Flex
Pillar Removal?
Has anyone removed the A, B or C pillars yet? I want to see how difficult it is to remove them, especially with the airbags in them. I plan to put a Sirius antenna on the roof and run the wire under the stock antenna base. Obviously I'll need to lower at least part of the headliner to get to the antenna base, so I thought I'd see if anyone has removed the pillars yet. Thanks in advance!
kmbkk is offline   Reply With Quote
Old 06-19-2012, 12:46 AM   #2
NRGBalanced
NRGBalanced's Avatar
Drives: '13 Subaru BRZ Limited WRB
otoz had a great write-up for getting the A pillar cover off to wire a radar detector:
http://www.ft86club.com/forums/showt...923#post239923
The others may not be much different. If you're just wiring, you may not need to remove, just loosen the cover.
NRGBalanced is offline   Reply With Quote
The Following User Says Thank You to NRGBalanced For This Useful Post:
chanomatik (07-01-2014)
Old 07-12-2015, 12:55 PM   #3
YEAHdams
Drives: 2013 frs 10series
Anyone know what the part number is of the white circle tab that goes into the frame next to where the airbag plugs in at? My airbag deployd and the "pros" that fixed it just smacked the A piller on and it smashed the white tab cause it wasn't in the hole. Smdh. -_- really want to avoid going back to the incompetent techs to fix it.
YEAHdams is offline   Reply With Quote
Exhaust tip removal Draco-REX Cosmetic Modification (Interior/Exterior/Lighting) 97 05-27-2017 06:50 PM
Scratch Removal? feldy Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 05-15-2014 11:12 PM
Rear seat removal? Shizuma BRZ First-Gen (2012+) — General Topics 34 04-01-2013 04:36 AM
FR-S Badge Removal skoodge Cosmetic Modification (Interior/Exterior/Lighting) 0 05-31-2012 01:46 AM
Removal of Radio/Infotainment Unit Captain Snooze Electronics | Audio | NAV | Infotainment 6 03-20-2012 08:46 AM
