Drives: 2013 Scion Fr-s
Endlinks Question
I was installing my coilovers today and during the process the nuts were stripped for the endlinks. One is actually still stuck on the OEM strut assembly. I do have new end links that came with my coilover, just waiting on the nuts. Is it safe to drive the car without end links for a few days while I wait for the parts? Of course I'll be driving as carefully as I can and only to and from work(around 5 miles round trip)
#2 |
Serial Cone Killer
Drives: '14 BRZ - WRB Premium 6MT
A) Make sure your sway bar is disconnected on the otherside.
B) If it it is the front sway bar, you are going to have significant oversteer, more so if you have a stiffer rear bar from OEM. If it is the rear sway bar, you are going to have a bias towards understeer, but since the car naturally has oversteer, it may be neutral. C) Just make sure the sway bar is disconnected on both sides. I can't stress this enough. D) Do not leave the endlink half installed, completely remove it until you have all the nuts you need to install completely. Do all that and the car should be fine, it just won't handle like you are used to.
#3 | |
And thanks for the response! |
#4 |
Serial Cone Killer
Probably not a terrible idea. I don't think that it will be a problem, but it would presumably be safer to do something along those lines.
| WTB FRONT ENDLINKS | fr_s | Want-To-Buy Requests | 2 | 06-25-2015 08:15 PM |
| OEM sway bars+endlinks | bjun | Brakes, Suspension, Chassis | 2 | 05-20-2015 10:37 AM |
| Alignments and endlinks question | radroach | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 10-02-2014 01:30 PM |
| WTS BC Coilovers and Endlinks | Wilso | Canada Classifieds | 5 | 09-21-2014 01:03 PM |
| Front Endlinks | goke186 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 08-31-2012 02:16 AM |
