Old 01-13-2013, 05:11 PM   #1
#87
I usually post drunk
#87's Avatar
Fumoto valve quick question
I installed mine today and I got the one with the small plastic nipple extension. I put it on with it and it extended about .5 to 1cm past the undertray. I didn't want to lose it so I took it off. Are you supposed to leave it on? Will it wear out (get loose/not fit) if I take it on and off with each oil change?
#87 is offline   Reply With Quote
Old 01-13-2013, 05:59 PM   #2
RavenFR-S
What is the point of putting a quik valve on if you plan to take it off for oil changes?? The whole point of a quik valve is to leave it on there forever.
May be I did not fully understand the question...
RavenFR-S is offline   Reply With Quote
Old 01-13-2013, 07:14 PM   #3
White64Goat
I have a feeling he may be talking about the nipple extension piece that you can slip a piece of tubing on, not the whole valve.
Old 01-13-2013, 07:16 PM   #4
#87
#87's Avatar
Yes, it's a white snap on nipple. The fumoto valve has a very short nipple the extension is about an inch long. The white piece in the picture below.
Old 01-13-2013, 07:24 PM   #5
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Take the plastic nipple off. You won't wear it out any time soon. You're only going to be using it every 3500 to 7000 miles.
The Following User Says Thank You to Draco-REX For This Useful Post:
Sportsguy83 (01-14-2013)
Old 01-13-2013, 07:45 PM   #6
gmookher
got the "S"
proper fit
Old 01-13-2013, 10:46 PM   #7
RavenFR-S
Oh okay, thanks for the clarification.
The Following User Says Thank You to RavenFR-S For This Useful Post:
Jertronic (07-20-2014)
Old 04-04-2013, 05:51 PM   #8
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
Detailed Questions about Fumoto Valves
I have some specific questions about the Fumoto Valve for the BRZ:
1: i thought the oil drain size is the same with FRS and BRZ, but on their website the part number is different. For FRS is F-103(N) and for BRZ it's F-105(N). I drive a BRZ, should i trust their site measurement just get the F-105?
2: On their website it says that if you use it for off-road vehicles, it's recommended to use a hose clip. Any of you guys use a hose clip on the twins? I'm a LITTLE worried about it being accidentally turned-on and drain the oil when i'm driving.
3. Has anyone experienced dirty or road salt clogging the opening?
4. When installing, what's the torque spec?
5. and where do you get the white plastic snap-on nipple? I don't see on their website.
Thanks
chenshuo is offline   Reply With Quote
Old 04-04-2013, 06:18 PM   #9
Foobar
SLO NO MO
Foobar's Avatar
Eh? Thought we used the F108?
The N doesn't come with the white nipple since it has a long nipple already. The S uses the white nipple.
Torque to 29 ft lbs.
Sent from my Nexus 4 using Tapatalk 2
Old 04-04-2013, 06:20 PM   #10
OrbitalEllipses
Drives: Attitude
Use the clip. $0.02 security measure...
kuhlka (11-23-2013)
Old 04-04-2013, 06:37 PM   #11
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
Never had it clogged on my impreza in CT after 5 years. also never opened, once you see the design you will know it never will.
chulooz is offline   Reply With Quote
The Following User Says Thank You to chulooz For This Useful Post:
Trap63 (01-03-2017)
Old 04-04-2013, 06:58 PM   #12
serial gixxer
What clip?
serial gixxer is offline   Reply With Quote
Old 04-04-2013, 07:30 PM   #13
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
There's an optional wire clip that prevents the valve from moving.
kuhlka (11-23-2013)
Old 04-04-2013, 07:56 PM   #14
Huehuecoyotl
Drives: Perrin/VORTECH Supercharger TestBRZ
I tossed on a hose clamp same result
Huehuecoyotl is offline   Reply With Quote
The Following 2 Users Say Thank You to Huehuecoyotl For This Useful Post:
Clipdat (04-04-2013), kuhlka (05-30-2014)
Installed Perrin shifter bushing & Fumoto oil drain valve zooki Engine, Exhaust, Transmission 23 03-31-2013 06:18 PM
FS: Fumoto quick valve Laika Engine, Exhaust, Bolt-Ons 1 01-08-2013 02:51 PM
Quick Question??? soontobrz BRZ First-Gen (2012+) — General Topics 12 12-16-2012 12:02 PM
Quick question.... be6sti Engine, Exhaust, Transmission 8 11-04-2012 10:53 PM
quick question about the height.. VenomRush Scion FR-S / Toyota 86 GT86 General Forum 13 12-22-2009 11:42 PM
