Drives: GT86 DGM
Optimal toe for daily/occational trackday
Had my car in at the dealership after I lowered it. They are technically within spec, but the toe is as close to 0 as they managed, and as a consequence my car is very nervous at speed and VERY sensitive to any ruts and poor roads.
What do I want to aim for for a nice stable high speed setup? I'd rather sacrifice a little turn-in to benefit motorway stability. |
#2 |
What are the actual specs you ended up with?
0 front toe and about 1/16" rear toe in isn't unstable on the highway, sounds like you might have some toe out?
| The Following User Says Thank You to wparsons For This Useful Post: | sittinSideways (06-02-2015) |
#3 |
@atledreier Being sensitive to ruts typically has to do with camber, not toe. Your tire isn't sitting flat on the ground to just go over the grooves. Instead it is cambered in and will be more likely to follow in the grooves.
#4 |
please post your alignment specs for reeeeal.
I'm -1.1 camber/toe out fr & -1.5 camber/toe in r no glaring issues at highway speed |
#5 |
Thanks
What are the actual measurements? toe out in front. toe in rear. my car feels great.
Awesome turn in. Zero nervous feeling on bumps or cruising.
| The Following User Says Thank You to ZionsWrath For This Useful Post: | CSG Mike (06-01-2015) |
#6 |
Drives: 2014 BRZ
What wheels and tires are you using?
#7 | |
Drives: 2005 Toyota Camry
My car is "very nervous at speed and VERY sensitive" to imperfections and crowns in the road. http://www.tirerack.com/tires/tirete....jsp?techid=47 -alex |
| The Following User Says Thank You to mav1178 For This Useful Post: | fika84 (06-01-2015) |
#8 |
Drives: GT86 DGM
Measured values after the alignment:
All values are left/right side and degrees Front: Caster: 5:48/5:54 Camber: -0.24 / -0.36 Toe: +0.03/+0.03 Rear: Camber: -1.54/-2.24 Toe: 0.0/0.0 So, it seems the front toe is actually very slightly positive, not sure if this is out or in, it doesn't say. The spec says minimum -0.45 and max +0.45 degrees, again, doesn't really give me anything to determine if it's in or out. The rear camber stands out as very uneven, but apparently that was the best they could do with no adjustable rear arms. The car is lowered just shy of an inch, and I run 20mm spacers front and 25mm rear. Stock wheels, 225/45-17 Michelin Pilot Sport 3 front and rear. |
#9 |
Drives: 2014 BRZ
You want a bit of toe in at the rear for stability. Probably should get some rear LCAs to fix the camber.
#11 | |
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
#12 | |
#13 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | DustinS (06-01-2015) |
#14 |
| Optimal tire for 17" rim | RealShkillz | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 31 | 10-20-2015 05:18 PM |
| what is the optimal rim and tire size for 1/4 mile? | Mike Brz | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 93 | 02-10-2015 12:17 AM |
| optimal settings for frs bespoke | jkr | Electronics | Audio | NAV | Infotainment | 9 | 08-27-2013 06:27 PM |
| optimal RTR setup | scottynoshotty | Tracking / Autocross / HPDE / Drifting | 28 | 03-03-2013 02:05 AM |
| Optimal tint (California mostly) | Oriental Life | Southern California | 49 | 08-17-2012 08:05 PM |
