Old 05-13-2015, 08:24 AM   #1
2ndgenhachi
Drives: 2013 fr-s, sr20 180sx
rev matching... only with tuning?
Ok. I've been reading through threads and saw posts that the twins only rev match with a tune like ecutek or oft. Well my stock tune '13 10 series DOES rev match... Can anybody clarify for me? Is this a 10 series thing? Am I misunderstanding rev match (under load the revs raise a few 100 rpm between shifts up and down clutch fully depressed no throttle)? Sorry for the kinda noob question. First time modding anything close to a new car. Btw car was purchased brand new 13 miles on the clock.
2ndgenhachi is offline   Reply With Quote
Old 05-13-2015, 08:46 AM   #2
rlpaul
Drives: point A to point C. Screw point B!
Rev match is usually a couple thousand RPM, not a few hundred. What I'd guess you're seeing is when the clutch is disengaged, the load is reduced, so the engine briefly revs slightly higher.
I don't notice it at lower revs, but I can hear it blip slightly higher when I'm shifting at over 4k RPMs.
rlpaul is offline   Reply With Quote
Old 05-13-2015, 08:58 AM   #3
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
Rev matching is when you down shift and you blip the throttle to match where the RPMs will be in the lower gear.
Your car doesn't have auto-blip unless it's an auto or used with a tune left on it. But you said your car was new, so that's not likely.
Old 05-13-2015, 10:30 AM   #4
TJ213
Drives:
OP, I think I may know what you're talking about.
When sitting in my driveway with the clutch in I noticed that when I put the shifter in any gear, especially reverse the revs raise a few hundred RPM. I posted up here about it because I had never seen a car do this before, and the response was that this is part of the stock ECU programming.
It's not rev matching, it sense more of an "anti-stall"
TJ213 is offline   Reply With Quote
Old 05-13-2015, 04:44 PM   #5
2ndgenhachi
Ok. Thanks for the clarification. Was just curious. never had a car with auto blip so I wasnt sure what it felt like.
Old 05-14-2015, 11:16 PM   #6
86Tony
Drives: 2015 AOZORA EDITION
Just feels like Rev matching but it does it for you automatically with the oft
86Tony is offline   Reply With Quote
Old 05-14-2015, 11:54 PM   #7
2ndgenhachi
I'll be using ecutek when my jrsc comes in.
AT not rev matching? Bergen23 Issues | Warranty | Recalls / TSB 25 12-17-2015 08:35 PM
Matching HID's and DRL's red_ZN6_4_you Cosmetic Modification (Interior/Exterior/Lighting) 16 11-24-2014 03:09 PM
Openflash rev matching cjsporl1996 Software Tuning 6 12-19-2013 12:04 AM
rev matching twoodcc BRZ First-Gen (2012+) — General Topics 86 11-06-2013 02:03 PM
Rev Matching Selvedge Engine, Exhaust, Transmission 17 11-11-2012 06:48 PM
