Drives: whiteout fr-s
rear lower control arm
I have kw v3 and am getting vorshlag camber plate for the front. just need rear lower control arm. I want the whiteline adjustable but they are on hold for the entire USA
. Looking for anyone with similar setup. 1) I want to know what lower control arm you use? 2) Why did you choose that brand? 3) What are your likes, and dislikes? Thank you |
| The Following User Says Thank You to FISHBURGLAR For This Useful Post: | mike_frs (04-22-2015) |
#2 |
Drives: 2014 Subaru BRZ
Im using kw v3 and i used oem top hats on both front and rear.
1. Stance LCA 2. I just wanted it. 3. It lowers the car another inch and increases the shock travel that could help if you lower your car. |
#3 |
Because compromise ®
Drives: Red Herring
| The Following 2 Users Say Thank You to Captain Snooze For This Useful Post: | mav1178 (04-21-2015), tooslow4umayne (08-07-2016) |
#4 |
If you want the best, albeit pricey, get the SPL.
#6 |
Drives: Many types of cars in R&D.
Not exactly answering your questions in order but I will post what I just wrote in another thread.
If the adjustments you wish to make are beyond the range of adjustments of factory toe links, yes you will need additional aftermarket toe links. Most of the time, however, staying at within 40mm of ride height lowering, and for very minor camber corrections, you can use the factory toe links as long as LCA has a setting near that of the stock arms and are not drastically different to accommodate "Stance hard parking" configurations... For most racing duties, we only need to get 2~3 degrees of static camber. Depending on the RCA of choice, the joints may be urethane, rubber, or hard ball joints. Anything harder than stock bushings will put progressively harder loads and impact on your suspension, and body sub-frame and uni-body structures. While going stiffer will provide a more direct feedback and retention of dynamic alignment on higher loads, simply going harder is not really always the best, and in fact rarely so on a part-time street driven car. The ideal setup is achieved for many reasons, such as what sort of machine you are looking to build, what your mix of daily driving to racing is, if this is a mixed role car, and finally your driver skill and goals, tastes, and factors of how you drive it. Fully stiffened ball jointed cars will give lightning response, but it usually get VERY tricky for the drivers, and it also reveals more seriously, any flaws in the rest of the car. Ball jointed ends also cause great deal of wear and tear on not just the joint itself, but anything it is attached to as there is no give for alignment pressures of arms in motion, nor constant hits the suspension takes from the road. Only really true dedicated race cars need such level of precision, and even at that, it may be overkill. There are MANY other joints and arms in the suspension too, and if those all are not replaced at the same time, the single hard joint will adversely affect alignment as it moves too. I will not discredit the role of adjustable LCA, and yes for some applications it is necessary to build a race car, and in other times, to increase the durability on things like competition rally cars. I had a role in designing the RS-R LCA we recently launched, as well as have been a test driver for Cusco versions very early in FRS inception. Both of them work very well for cars that need it, but it isn't frequent on daily driven Sunday racers to need that level of adjustments or durability levels. RSR LCA uses a high quality polyurethane joint for good pairing with stock parts mixed in the toe control as well as racing arms, and do have an optional ball joint you can purchase if the goal is a more hard core race car build strictly for tracks-and sub 200 UTQG tires. Cusco ones are ball-jointed and are proven in hardest of rally racing too, as the unit is also compatible for Subaru WRX's that see a ton of rally action all over. But like I have said, the Stock LCA are also, very good for this car and suffices for most non- high level competition casual track fun. Best recommendation is to use a rubber or polyurethane bushing equipped LCA, that has some 'give' so that the rest of the suspension can work in unison, and to balance out the design of the rest of that car, that will NOT be seeing equal amounts of bracing, welding, gusseting, pinch-welding, and caging, to even out the rigidity. Big beefy adjustable LCA isn't really too critical in this sense, as natural camber for FRS suspension statically is nearly 2 degrees at 30mm drop, and it's still within range to be happy on handling with stock LCA. So if you are doing it partly for visual appeal, by all means, but since you will be setting it very close to the stock dimensions for the most part in a daily driven occasional racer with street tires, it really isn't high on priority for most casual Sunday track folks. Best then to save the $500 to spend on better properly designed shocks, and tires that suite the role best, which will do wonders to handling of the FRS. __________________ Summary: RSR uses high quality and precision fit polyurethane bushings on the LCA, and can also be ordered with ball joints if it is a race car build dedicated for the track on ultra-high grip tires. It is also equipped with triple range adjustment for sway bar stiffness end points, as well as triple mounts for shock ends to adjust the coilover stiffness and stroke range too. It also has dual position hub bracket so that ride-height, damping stroke range, and arm angle can be adjusted as well. It's been designed primarily from the FRS platform as RSR does not race a WRX, and RSR does race and supply a fleet of Toyota 86's for teams in pro-drifting, road racing, autocrosses, and other sports. Cusco uses sealed ball joints, and is designed with maximum rigidity and durability that is born from necessity in their rally and road racing use on WRX's that see huge abuse. Yes the WRX and STI LCA are nearly the same dimensions stock so adjustable LCA can work equally well in FRS and Imprezas for almost all makes of adjustable LCA, which is what Cusco does, and does VERY well. (and anyone who is replicating their design)
Moto Miwa
www.club4ag.com R&D Driving Engineer, Product Planning Consultant Consulting Member at Cusco, OEM+, RS-R. www.club4ag.com Last edited by Moto-P; 04-22-2015 at 12:41 AM. |
| The Following 9 Users Say Thank You to Moto-P For This Useful Post: | BRZ RN (07-16-2015), Captain Snooze (04-22-2015), continuecrushing (04-22-2015), Efferalgan (04-22-2015), Hyper4mance2k (04-22-2015), jlugo711 (05-21-2015), lead82 (04-30-2015), Rookie84 (04-22-2015), Vincent Nguyen (10-23-2016) |
#7 |
Now going back to your setup, the KW-V3 are not height adjustable beyond spring perch adjustment within the designed stroke range of piston within the shocks, as these do not have a bottom bracket adjustments to position the entire assembly up and down while retaining proper stroke range.
That being said your height adjustment range is very limited. Getting something with shock mount position and hub mount choices like the RSR (or similar design) may fit you well and give you a little more room to tweak the KW-V3. Since the V3 are not dedicated track duty shock but more a daily-driver sport shocks that can accommodate casual weekend motorsports to an extent, the setup shouldn't be too hard-core, so characters all match with the rest of the car. The polyurethane bushing or rubber ends then, should work better to retain the nice road manners on rough surface of US roads as well as most grassroots level race tracks. And it is best when coupled with 200 UTQG Treadwear or less sports tires, and nothing much more sticky to give you the most precision and balance. That would be my simple answer to a question that can be elaborated much more if needed.
Moto Miwa
www.club4ag.com R&D Driving Engineer, Product Planning Consultant Consulting Member at Cusco, OEM+, RS-R. www.club4ag.com |
| The Following 5 Users Say Thank You to Moto-P For This Useful Post: | Bahraini86 (04-27-2015), BRZ RN (07-16-2015), FISHBURGLAR (04-22-2015), ohmikegoodness (05-20-2019), Rookie84 (04-22-2015) |
#8 |
Drives: 2014 BRZ
Really enjoying the SPL LCA. I can really feel what the rear is doing on track and I haven't noticed any downside in ride quality or NVH.
#9 | |
Drives: 2015 Subaru BRZ Limited
![]() I'm wondering if I drop it 2" without a camber kit, wonder if I will eat tired like crazy :/ Debating on whether I should install the coilovers or just hold off on the install and save up and buy lca's... and would i need adjustable toe links as well? |
#10 | |
Drives: 2015 Fire
Very good information here much appreciated. So for me (I simply want to make the car look better, maybe a 2 inch drop all around. Will you say stock LCA should be ok? Thanks |
#11 | |
honestly im not too sure, since im not an expert in suspension; but i think 2'' is a big drop to not have a means to adjust camber. im figuring out how i am going to go about this. As i want to get any bushings arms and all that to get it done at once. |
#12 | |
Drives: 2005 Toyota Camry
1) why do you need camber adjustment? Are you going past 2 degrees negative? 2) what is your budget? 3) what do you do with your car? |
#13 | |
i want to get a bit past 2 degree camber. i want consistant camber. budget is watever necessary to get the car where i want it. i dd my car put about 60 miles a day plus, i take back roads and beautiful hard drives almost daily. |
#14 | |
Drives: brz
| The Following User Says Thank You to adamg For This Useful Post: | mike_frs (04-22-2015) |
| FS: OEM Rear Lower Control Arm | MicheleAbbate | Brakes, Suspension, Chassis | 23 | 12-31-2018 04:48 PM |
| Rear lower control arm dim | theGonz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 02-19-2015 01:44 PM |
| SPL Arms - Brand New! - Rear Lower Control Arm + Rear Toe Arm w/ Eccentric Lockout | quiet-k | Brakes, Suspension, Chassis | 8 | 03-22-2014 11:17 PM |
| WTB: Front Lower Control Arm and Rear Upper Control Arm | YDNA | Brakes, Suspension, Chassis | 0 | 11-10-2013 05:40 AM |
| Hancha Rear Lower Control Arm | Hancha Group | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 62 | 09-21-2013 11:47 AM |
