Old 03-29-2015, 11:30 PM   #1
FRSure
Drives: Toyota
Curb hit
I have a little bit dilemma here, just want to get some answers from you guys.
> Was trying to get some food from McDonald, wheel hits curb (wasn't paying attention), now my steering wheel is off center. Is slightly tilted to the left. At highway speed (55 mph - 70 mph), the steering center is NOT shaking, nor is my car pulling to the side that much (very very little).
What could be the problem?
FRSure is offline   Reply With Quote
Old 03-29-2015, 11:32 PM   #2
shellslinger
Drives: Whiteout FRS
Appears you may need an alignment but have the mechanic to verify no other parts are damaged.
shellslinger is offline   Reply With Quote
The Following User Says Thank You to shellslinger For This Useful Post:
Choco (03-30-2015)
Old 03-29-2015, 11:33 PM   #3
PBlack09
PBlack09's Avatar
Drives: 2015 Scion FR-S Firestorm
Sounds like an alignment problem.
PBlack09 is offline   Reply With Quote
The Following User Says Thank You to PBlack09 For This Useful Post:
Choco (03-30-2015)
Old 03-29-2015, 11:34 PM   #4
FRSure
Drives: Toyota
Yeah. Definitely need an alignment! Just wanted to make sure that no other parts are broken. I hit the curb around.. 7-10mph?
http://mywethersfield.org/wp-content...ellow-curb.jpg
Ran over one of these when turning my car.
The Following User Says Thank You to FRSure For This Useful Post:
Choco (03-30-2015)
Old 03-29-2015, 11:37 PM   #5
AlanLGuy
Drives: Raven 6 speed Manual FRS
Could have bent a tie rod. Have the shop check when you take it in for an alignment
2013 6-Speed Raven Black Scion FRS - Unmolested, for now
2000 Celica GT-S - "Frankenstein" CAI, Boosted2.0 Ported Header, TRD Exhaust, ES Motor Mount Inserts, ES Suspension Bushings, Southbend TZ clutch, Fidanza Flywheel.
AlanLGuy is offline   Reply With Quote
The Following User Says Thank You to AlanLGuy For This Useful Post:
Choco (03-30-2015)
Old 03-29-2015, 11:39 PM   #6
swarb
Car is totaled.
j/k
At slow speed most likely nothing is broken, possibly a bent tierod, an alignment shop should help you out, just mention to them which corner you hit and maybe they can double check.
The Following User Says Thank You to swarb For This Useful Post:
Choco (03-30-2015)
Old 03-29-2015, 11:39 PM   #7
FRSure
Drives: Toyota
Gonna give PTuning and MachV Motorsports a call tomorrow.
What are the chances that something else is broken?
Old 03-29-2015, 11:45 PM   #8
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Chances are something is bent
N1rve
Old 03-29-2015, 11:51 PM   #9
swarb
Those two shops are good. Chances are they will be able to help you fix everything back to 100%
Old 03-30-2015, 08:43 AM   #10
Sony
Sony's Avatar
Drives: 2013 Subaru BRZ MT Limited
Like others have said, most likely a bent tie rod if anything. Tie rods are usually the weakest part and are the first thing to get bent and messed up when you hit something like a curb. It's unlikely you bent your Lower Control Arm at only 7-10mph and you would probably feel more shaking and vibrations in the steering wheel if you did.
PTuning and MachV are both known as reputable shops around these parts so you're in good hands. Luckily a Tie Rod is a pretty cheap and easy fix relatively speaking! Should cost you a couple hundred dollars.
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder
Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake
Sony is offline   Reply With Quote
Old 03-30-2015, 08:51 AM   #11
bigred18
MJLONIR Program Member
bigred18's Avatar
Drives: 2014 Scion FR-S
Originally Posted by swarb View Post
Car is totaled.
j/k
Ran over this going almost 35mph (slowed down for it). Saw a car backing up in the distance thinking, "What is he do--SHHHEEEEE---!" These are the problems when its dark, 0430, your friend booked the only flight in the morning, and he asked for a ride to the airport. Long story short, I pulled off, made sure nothing was cracked/broken (amazes me nothing was), and verified the alignment was not compromised. Just had an inspection and nothing was reported wrong.
ドラゴンに乗る
Instagram: Komodo_Actual
My car build: http://www.ft86club.com/forums/showthread.php?t=81094
bigred18 is offline   Reply With Quote
Old 03-30-2015, 05:43 PM   #12
driftguy
driftguy's Avatar
Drives: In between cars... 2018 Ninja 1000
Yeah I'd imagine running over the top half of a Suburban might do some damage.
Seriously though, what is that you hit? Railroad tracks?
driftguy is offline   Reply With Quote
The Following User Says Thank You to driftguy For This Useful Post:
Tcoat (03-30-2015)
Old 03-30-2015, 05:55 PM   #13
bigred18 (03-31-2015)
Old 03-30-2015, 05:59 PM   #14
swarb
Tcoat (03-30-2015)
I dun goofed into a curb sittinSideways Scion FR-S / Toyota 86 GT86 General Forum 17 03-31-2015 12:00 AM
Curb rash what should i do? Rocket.BRZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 06-02-2014 08:38 PM
Spun out and hit a curb... JohnAyySays Issues | Warranty | Recalls / TSB 54 12-09-2013 11:59 AM
Hit a curb :( aakash New England 0 10-14-2013 11:04 PM
Hit a curb Itssrayyxd Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 02-08-2013 11:09 PM
