Old 06-24-2017, 11:28 AM   #1
btan219
Drives: DGM 15' BRZ Limited
Which interior fuse slot to install led interior lighting in?
I got the Opt7 Aura led strips. Which of the fuse numbers in the interior fuse box can I use to have it have power only when the car is on? Also, would it be better if I install it in the hood fuse box instead or does it not matter.
Thanks
btan219 is offline   Reply With Quote
Old 06-27-2017, 02:28 PM   #2
btan219
kind of weird no one responded to this... o well i think i found a video tutorial showing how to install interior lighting. and yes i was aware theres an interior lighting thread but theres a lot of pages in it and i didn't see an actual post about how to actually install it
Old 06-27-2017, 02:43 PM   #3
shadow_772
Drives: 2014 BRZ Limited
Poke the blank slots (if there are any, I haven't looked at my fuse box yet) with a test light and see if there are any that come on when the car turns on and use it. If you have issues I can go check mine and see what I come up with, but it should be super easy.
shadow_772 is offline   Reply With Quote
Old 06-27-2017, 03:09 PM   #4
Chimera
Drives: FRS
I used the heated seats circuit(s)
The Following User Says Thank You to Chimera For This Useful Post:
btan219 (06-27-2017)
Old 06-27-2017, 09:14 PM   #5
btan219
What are the chances a bunch of fuse slots don't work? I plugged it into all the empty slots in the red column but none lit up. When I plugged them into the empty green slots they worked. The green column seems to be the ones on even without the ignition.
So at least I know it's not the product since they work on the slots for always on power. Also one of the FT86SpeedFactory tutorials used one of the slots in the red column. Any ideas for a fix?
Old 06-27-2017, 09:17 PM   #6
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
Pick up and splice into a switched live wire?
From the radio?
Scrappydoo is offline   Reply With Quote
Old 06-27-2017, 09:19 PM   #7
btan219
hm I want to leave having to splice as a later resort. Are all those fuse slots that didn't work really busted?
Old 06-27-2017, 09:24 PM   #8
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
Just not wired I'd suspect. If there not working, there not working.
Two second job to splice using a scotchlok. Temporary too so you can remove it when you want to.
The Following User Says Thank You to Scrappydoo For This Useful Post:
Old 06-27-2017, 09:49 PM   #9
shadow_772
It all depends, some things will only come on with headlights and the like. Other blank slots may be just that.
The Following User Says Thank You to shadow_772 For This Useful Post:
Old 06-27-2017, 09:54 PM   #10
btan219
Is it normal though for all those blank fuses to not work? It is what it is I suppose
Old 06-27-2017, 11:39 PM   #11
Chimera
Drives: FRS
Yes it is normal
Old 06-27-2017, 11:43 PM   #12
btan219
Originally Posted by Chimera View Post
Yes it is normal
True. I'll take your advice and use the heated seat slot since I don't think I'd ever use mine. Thanks
GCS interior lighting FR-Sky Cosmetic Modification (Interior/Exterior/Lighting) 6 10-10-2019 06:55 PM
brz interior fuse cover shaynek Want-To-Buy Requests 3 03-01-2016 06:03 PM
Interior Lighting ... REAV3R Hawaii 0 02-16-2015 04:33 AM
LED interior lighting for BRZ cslntuee Cosmetic Modification (Interior/Exterior/Lighting) 7 02-06-2013 03:43 PM
interior lighting? fistpoint Scion FR-S / Toyota 86 GT86 General Forum 2 05-09-2012 02:52 AM
