Old 01-19-2015, 06:28 PM   #1
Akari
Drives: 2013 DGM BRZ
How to adjust tune for different tire size?
Hey all,
I'm running a slightly non-standard tire size that has my speedo off a couple percent throughout the rev range. I've looked and searched around but haven't yet found a place to change this in the tune.
Does anyone know if this is possible and if so what steps need to be taken? -I work in RomRaider with a OFT tune and definitions.
Thanks!
Akari is offline   Reply With Quote
Old 01-19-2015, 06:35 PM   #2
mad_sb
Drives: 2013 Asphalt FR-S
I don't think the speedo calibration is part of the engine ecu, which is what we have access too with the current tuning tools. Possibly one of the other ECU's though not sure.
Old 01-19-2015, 06:45 PM   #3
steve99
Drives: FT86
Im pretty sure what mad-sb said is correct, you can adjist gear display rpm thresholds to correct thge in dash display in ecu rom but not the speedometer correction.
However when i was messing with the toyota techstrem software i seem to remember a speedometer calibration adjustment in their. you can get software and adapter for about $40 on ebay seatch for techstream.
Old 01-19-2015, 07:35 PM   #4
Akari
Thanks Steve, I'll explore that option and see if that leads anywhere.
Part of me wonders if this is possible in a tune but just not defined as a table/parameter yet?
Old 01-21-2015, 09:47 AM   #5
Toyota John
Calle Atun
Drives: 13 FRS, 93 Mr2, 85 ae86
Confirmed techstream works with tactrix op2 cable. I haven't looked into tire size re-calibration yet.
Toyota John is offline   Reply With Quote
Tire size help sharris721 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-19-2014 01:03 AM
Tire Size and Ecutek Tune - Stupid question Pokeguyjai Software Tuning 5 10-04-2013 12:43 PM
Appropriate tire size for 250-350 whp Tiz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 07-12-2013 03:40 PM
225/35/18 Tire Size? stoneman155 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 03-29-2013 09:09 PM
Tire Size help! J-Money Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 02-04-2013 01:04 PM
