Old 06-03-2020, 07:30 PM   #1
airrick
Drives: TRD R.S. 1.0 FRS
Ecutek bluetooth connect issue
Hello,
I got tuned with ecutek at theracersline. I purchased the tune and license. And i later got an ecutek bluetooth dongle. Ive paired it with my phone and the light on the ecutek dongle is solid blue. But when i try to access my car’s data. It just days no vehicle interface. So im confused and just want to datalog my car.
Any advise would be greatly appreciated.
airrick is offline   Reply With Quote
Old 06-03-2020, 07:46 PM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Is your car running when doing this? Have you unplugged and plugged the connector back in? I had to use an ODB2 extender cable to get my OBD2 port to be reliable, I frequently had connection issues previously
Old 06-03-2020, 07:51 PM   #3
airrick
Ive tried all of those things. Ive tried it with my car running and with the car in the on position same thing. Wont let see my data. Seems like i might have that issue as well but the thing is the light never flickers or anything im connected via bluetooth solidly
Old 06-03-2020, 08:19 PM   #4
DarkPira7e
DarkPira7e's Avatar
Have you tried installing ECUtek on a different Bluetooth enabled device?
Old 06-03-2020, 09:19 PM   #5
airrick
i have not. I'm a bit confused what the usb deskey is for though.
I did order a OBD2 port extender, im thinking it is that. But i can't download ProEcu on my computer.
Old 06-03-2020, 10:01 PM   #6
DarkPira7e
DarkPira7e's Avatar
Just to be sure it's said, the Bluetooth kit is meant to connect with the Ecutek Connect Bluetooth app on a smartphone or tablet, it is not meant to interface with a Windows or Mac operating system on a computer.
The deskey is what allows ECUtek proecu to run on the computer, it needs to be in a USB port on the computer anytime proecu is running, your license is tied to that dongle
Old 06-03-2020, 11:33 PM   #7
86TOYO2k17
Drives: 2017 toyota 86
+1 for OBD cable extension.
Old 06-04-2020, 02:46 AM   #8
tomm.brz
Drives: brz 2017 hksv2
do you have a samsung
i heard of some Samsung top end that would n tconnect to it no matter what
Old 06-04-2020, 05:20 PM   #9
EndlessAzure
Wheels for Brains
EndlessAzure's Avatar
It's probably the OBD port on the car. The car's pin receivers are pretty wide and have loose tolerance versus the tiny pins on the Bluetooth Connect Module.
If you pick-up an OBD extender/adapter cable, it will probably resolve your issue. That's what I needed for mine because the power pins weren't making good contact.
EndlessAzure is offline   Reply With Quote
Old 06-04-2020, 06:44 PM   #10
airrick
Yup , cause I was bored last night. I tried desperately, it worked! I fiddled with it, and of course, it disconnects but eventually i made it work. I was so happy i left it in there. I recalled reading something about the bluetooth dongle doesnt use much power can even leave on over night. haha I did that.
I ordered an OBD2 extender. The vendor bought the dongle from finally registered my kit, ProEcu yay. all is well. maybe.
The Following User Says Thank You to airrick For This Useful Post:
DarkPira7e (06-04-2020)
Ecutek Bluetooth Interface Kit / ECU Connect Luftwaffel Software Tuning 161 11-26-2020 07:01 PM
ECUTek Connect Bluetooth -- SOLD toast Audio/Visual, Electronics, Infotainment, NAV 1 03-10-2020 05:01 PM
FS: Ecutek ECU Connect Bluetooth byun Audio/Visual, Electronics, Infotainment, NAV 1 02-21-2017 04:18 PM
Garmin GPS Bluetooth Won't Connect frssfo Electronics | Audio | NAV | Infotainment 0 08-20-2014 10:55 PM
Bluetooth connect mutes android NAV Rob_g Electronics | Audio | NAV | Infotainment 6 07-04-2012 04:38 PM
