Old 11-20-2014, 07:32 PM   #1
KraftWerks
KraftWerks's Avatar
Drives: Kraftwerks BRZ
Skunk2 Lowering Springs NOW AVAILABLE!
Corner faster, stop quicker, and improve the look of your vehicle with Skunk2's legendary Lowering Springs.Skunk2 Lowering Springs for the 2013+ BRZ/FRS are designed to dramatically improve handling performance and driver feel through significantly increased cornering grip and reduced body roll. What’s more, Skunk2 Lowering Springs also help counteract squatting under acceleration as well as nose-diving while braking. All Skunk2 Lowering Springs are CNC-wound using the highest quality SAE 9254V spring steel, shot-peen stress relieved, and corrosion-protected thanks to powdercoating and specialized phosphate treating processes. The results are a lower center of gravity and race car-like handling, yet smooth, comfortable ride characteristics—the perfect balance between performance and comfort. Skunk2 Lowering Springs are compatible with OEM or aftermarket shock absorbers and look great on vehicles with stock or aftermarket wheels.
Part Number: 519-12-1001
MSRP: $262.49
http://store.skunk2.com/suspension-t...g-springs.html
→ Pictures of shop BRZ w/ Springs Installed ←
KraftWerks is offline   Reply With Quote
Old 11-20-2014, 08:11 PM   #2
DAEMANO
Time Traveller
@KraftWerks
Thanks for the post.
From the site it says these drop (Front / Rear): 1.5” / 1.5”. Which would make them some of the lowest springs available. Do you have the spring rates, and also, do they come with replacement bump stops or do you recommend trimming the OEM bump stops and if so, how much?
Thanks
Old 11-21-2014, 02:37 PM   #3
KraftWerks
KraftWerks's Avatar
Originally Posted by DAEMANO View Post
@KraftWerks
Thanks
Our apologies, we're actually about (Front / Rear): 1.4" / 1.6".
Rates should be right about 3.5K / 5k respectively.
On our BRZ, we installed on OE shocks with OE bump stops, no issues. We've had varying weights of drivings in the vehicle with no hint of bottoming out, riding the stops, etc. If anything, you can trim the OE stop no more than .5" or so just to be safe but unless you're completely loaded down like you're taking the vehicle camping, you shouldn't need to trim at all.
I suppose this MAY also come into play but if you have absolutely horrid roads, the trimming may be considered as the vehicle is going to operate differently compared to on a completely smooth surface or close to it.
The Following User Says Thank You to KraftWerks For This Useful Post:
DAEMANO (11-21-2014)
Old 11-21-2014, 05:18 PM   #4
GotBRZ1691
GotBRZ1691's Avatar
Drives: 2014 Subaru BRZ Limited 6smt
Need someone on the forum to test em out
GotBRZ1691 is offline   Reply With Quote
Old 11-21-2014, 06:27 PM   #5
KraftWerks
KraftWerks's Avatar
If you want to be THAT guy, shoot me a PM.
We can work out a deal for helping us out with 3rd Party Feedback. =D
Old 11-21-2014, 07:13 PM   #6
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by KraftWerks View Post
Front / Rear 3.5K / 5k
For the lazy that's 196 lbs/in / 280 lbs/in
The Following User Says Thank You to Calum For This Useful Post:
KraftWerks (11-21-2014)
Old 11-22-2014, 01:39 PM   #7
GotBRZ1691
GotBRZ1691's Avatar
I'll Be that Guy
The Following User Says Thank You to GotBRZ1691 For This Useful Post:
KraftWerks (11-24-2014)
Old 11-24-2014, 03:56 PM   #8
KraftWerks
KraftWerks's Avatar
I'll Be that Guy
PM Replied. =D
Old 11-25-2014, 10:17 AM   #9
GT86meMR2
GT86meMR2's Avatar
Drives: MR Spyder/GT86
So are Lca's needed when you go for these springs or do they not change handling in a negative way on their own?
GT86
Current Mods: Ace Header with 350 OP-Berk Frontpipe-Miltek Resonated Catback-OFT-k&n drop in filter
GT86meMR2 is offline   Reply With Quote
Old 11-25-2014, 01:08 PM   #10
KraftWerks
KraftWerks's Avatar
These are actually on our own shop BRZ right now with factory EVERYTHING in terms of suspension - aside from the springs. There was no uneven tire-wear last we were able to check.
Are items like that recommended when lowering the vehicle or changing the geometry of the vehicle in any way, certainly.
JonAvalon (11-25-2014)
Old 11-25-2014, 01:24 PM   #11
JonAvalon
SCBYD0
JonAvalon's Avatar
Drives: 18 BRZ (WRB)
I may snag these during the current Black Friday sales. The drop is lower than I'd like but i don't mind it.
@KraftWerks do you have any pics of the shop BRZ with these installed?
JonAvalon is offline   Reply With Quote
Old 11-25-2014, 06:07 PM   #12
KraftWerks
KraftWerks's Avatar
I will have pictures up shortly of our shop BRZ.
Old 11-25-2014, 10:28 PM   #13
Rulin
WRX -> BRZ. (TX)
Rulin's Avatar
Drives: 2015 Series.Blue WRB
I'm very anxious for the pictures too, I've been back and forth between between dropping the car or not.
Edit: if you're looking for any other testers, I'd be happy to give them a go as well
Sent from my Nexus 5 using NASIOC mobile app
KraftWerks c3094 SC Kit
ARK GRiP w/ test pipe
KW V3
OEM Audio + Reference 400CF
Rulin is offline   Reply With Quote
The Following 2 Users Say Thank You to Rulin For This Useful Post:
JonAvalon (11-26-2014), KraftWerks (11-26-2014)
Old 11-26-2014, 01:56 AM   #14
iniguez310
Cool Guy
just installed these today! if you guys want more pics just ask
iniguez310 is offline   Reply With Quote
The Following User Says Thank You to iniguez310 For This Useful Post:
WTB trd lowering springs Heyitsryan Want-To-Buy Requests 0 07-20-2014 01:52 AM
WTB: Lowering Springs iamdaspoon Brakes, Suspension, Chassis 4 07-16-2014 09:45 PM
which lowering springs should I get? abling2 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 05-22-2013 03:27 PM
RS*R Lowering Springs Soon to be out! tintumz22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 01-16-2013 03:39 PM
Lowering springs HELP FRS_13 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 10-27-2012 11:03 PM
