Old 02-02-2014, 09:43 AM   #1
trueno86power
[||•]=(86)=[•||]
trueno86power's Avatar
Drives: 2017 Toyota 86
Quick tips for Remote Start installation
First I'm not going to tell you how to install a remote start. Do your research for the wiring diagram and module programation. If you never done a full remote start install well leave it to the pro. You can dammage the BCM/ECM if you don't know what you are doing !
Usefull links: http://www.idatalink.com/
http://www.autostart.ca/
http://www.ft86club.com/forums/showthread.php?p=1166113
I will provide you some quick tips for the FR-S/BRZ that will help you out with the install.
Recomanded Hardware
- Bypass Idatalink ADS-AL-CA
- Autostart Remote start
- Positive door lock inverter
- 2 Diodes
- 2 Relays
All the Autostart module are fully compatible with Idatalink bypass. Choose the "ADS" option.
Quick tips
- You can only do normal key FR-S/BRZ with Idatalink. (No push start) **EDIT: Look like Idatalink released a version for push start FR-S/BRZ !
- You don't need 2 Idatalink module. Every signal you need can be hardwire by the BCM/ECM and you will save 50-80$ on the installation. Idatalink will warn you that 2 module is needed but it work perfecly with 1 module. Just take care to select the immobiliser version flash.
- FRS/BRZ have two ignition and starter wire. They got to be powered when remote start. Don't use the same wire to power up 2 wires of the car. It can becaume dangerous if these wires shorts for whatever reasons. Use 2 separetes Igntion and Starter source. Autostart module have 2 starter outputs and you can use the "negative ignition output" with a relay to invert to positive for the other ignition.
- Manuals only: For the dome lamp input, don't connect on the dome output wire. When you remove the key sense, the dome lamp goes on and the remote start module will see an intrusion everytime you try to make your ready mode sequance. Plug at each door switch with diodes like this:
- OEM door locks with the remote don't work when the ignition sense detect a key. So in remote start, the OEM remote will not unlock/lock the doors.
- The door lock switch is POSITIVE. The shop manual indicate that they are negative but it's not true. You can buy a little positive door lock inverter for less than 10$.
- Clutch is positive. Use a relay to invert to positive the "Ground when running" from the remote start.
- The best RPM source is an ignition coil. ECM is located on the passenger side so it's really easy to take a coil signal here.
Don't forget to solders all the wire correcly, attach every wire/module and try that all the OEM functions still work correcly.
Hope that all these tips will help you out, like I've told you I'm not to guide you with the full instalation, It's only the tips that I've found out on my first install on a FR-S
trueno86power
GR | TOM'S | TRD
2017 Toyota 86
trueno86power is offline   Reply With Quote
The Following User Says Thank You to trueno86power For This Useful Post:
luv85 (02-22-2014)
Old 02-14-2014, 12:55 PM   #2
DrewIsAmus
Drives: Dark Grey Metallic 2013 Subaru BRZ
Remote start for push button cars.
Click here!
DrewIsAmus is offline   Reply With Quote
Old 09-24-2014, 01:04 PM   #3
bren5279
Drives: series.blurrr
Sry to bump an old thread, but working on installing a Viper remote start (and possibly DIY)
Why does the BRZ/frs have 2 ignition and 2 starter wires?
And why exactly cant you tie both into the ignition and starter outputs? Too much power draw from the remote start?
bren5279 is offline   Reply With Quote
Old 09-24-2014, 10:28 PM   #4
trueno86power
[||•]=(86)=[•||]
I assume to isolate better circuit agains faults ! Don't know why they desing it that way.
You really don't wan't to tie both circuit... It can be reallly dangerous....
Let say that you have a 40AMP fused 12V circuit and a 10AMP fused 12V circuit. On the 10Amp circuit, theirs a short to ground. So the OEM fuse blow, the system dosent work but it was protected.
Now you remote start your car... The 40AMP circuit will power up the shorted circuit with a 40AMP fuse... Small wire will not make a 40AMP fuse blow, the wire will take fire of it's own before the fuse will even be close to burn.
So that's why I'm telling you it's dangerous to power up 2 alimentation with the same source.
trueno86power
GR | TOM'S | TRD
2017 Toyota 86
Old 10-01-2014, 12:52 AM   #5
bren5279
Oh ok. Heres a good diagram for anyone wondering
http://www.the12volt.com/installbay/...g_644_3001.pdf
http://k.b5z.net/i/u/6000490/i/pdf_d...Wire_Relay.pdf
Old 10-03-2014, 06:01 PM   #6
bren5279
Is there a neutral position sensor for our manual transmissions by any chance?
Old 11-29-2014, 12:07 PM   #7
bren5279
So do we need an immobilizer bypass unit?
Old 11-30-2014, 09:03 AM   #8
trueno86power
[||•]=(86)=[•||]
Ehm no and I've never work on any car that have a "neutral sensor".
And YES you need it like I've written in the OP.
READ the first post correctly but I'll quote myself:
trueno86power
GR | TOM'S | TRD
2017 Toyota 86
Old 11-30-2014, 08:35 PM   #9
bren5279
Ive done one, three as a matter o fact, Was just hoping that by some odd chance it had one.
And yeah I answered my own question just forgot to delete it. Didn't realize that the smart key module acted as it
Old 12-05-2014, 04:19 PM   #10
bren5279
Turns out there is a neutral sensor wire
Old 12-05-2014, 11:01 PM   #11
jonzhuxD
Drives: Ultramarine FR-S
The neutral position sensor is a green/black wire at the ECM behind (more like under) the glovebox. I've used it in my AdvancedKeys install and can confirm it's there.
You can look at this wiring diagram here in this thread.
Here's a direct link
http://www.mediafire.com/view/7j74hh...ire_Gauges.pdf
jonzhuxD is offline   Reply With Quote
Old 12-06-2014, 01:18 PM   #12
bren5279
Yep got it!
Old 12-07-2014, 04:47 PM   #13
bren5279
Ok so I think Ive got everything but one thing down: Is the (+)starter input (not the 12v supply input) needed? Ive got the two starter ins and 2 starter outs but Im wondering if thats necessary? and if so does it just go to the starter wire too?
Remote Start Anyone? arleewa BRZ First-Gen (2012+) — General Topics 43 08-20-2014 03:43 PM
Remote Start W/Smart Key calispec Electronics | Audio | NAV | Infotainment 25 05-15-2014 04:25 PM
Scion Factory Remote Start? mikeg7827 Electronics | Audio | NAV | Infotainment 16 12-24-2013 02:00 AM
Remote start Flako Electronics | Audio | NAV | Infotainment 4 11-26-2013 03:32 PM
Request remote start info Fallen hero Scion FR-S / Toyota 86 GT86 General Forum 0 12-21-2012 01:32 PM
