Old 12-04-2014, 07:17 PM   #1
benlaz88
Drives: 2013 Asphalt FRS
Is this normal in the OFT??
While having my OFT plug in, I see my LTFT is running really high (8-10%). When i start to accelerate, the LTFT drop however, when i just let go my throttler and let my car roll, LTFT automatic go back to 8-10%. Is the normal at all? Also, i should mention, I had my new JDL header/Overpipe install past week and with the aftermarket test pipe, catback, and intake. Any thought or opinion would be awesome.
Thanks
benlaz88 is offline   Reply With Quote
Old 12-04-2014, 08:14 PM   #2
JB86'd
JB86'd's Avatar
Drives: JAWS
Intake probly causing that..look up MAF scaling
JB86'd is offline   Reply With Quote
Old 12-04-2014, 08:21 PM   #3
Malt
Drives: 2015 WRX
Thanks
I have the same issue at extremely light throttle. Scaling the MAF might correct it to some degree but if the closed loop fueling isn't tuned for your mods you won't get it "perfect".
Malt is offline   Reply With Quote
Old 12-04-2014, 09:47 PM   #4
fantah
fantah's Avatar
Drives: 2013 BRZ Premium Black
Have to MAF scale for your Intake. Do you have after market ones? OFT OTS tunes are designed for Drop-in / stock filter, if you've changed the intake the MAF have to be adjusted for the new intake.
fantah is offline   Reply With Quote
Old 12-04-2014, 10:23 PM   #5
steve99
Drives: FT86
see here for maf scaling its nothing to do with oft. OFT tunes are done for stock intakes, if you change your intake you will need to rescale your maf for best results if you have perrin or takeda intaake their are some pre done scales at end og post above.
for best results individual maf scaling is best.
http://www.ft86club.com/forums/showthread.php?t=64790
Is it normal? WGMGR BRZ First-Gen (2012+) — General Topics 3 12-02-2014 04:11 PM
Is this normal? BlackyRose Engine, Exhaust, Transmission 8 10-04-2013 12:54 PM
Does this look normal to you? white_knight Issues | Warranty | Recalls / TSB 13 03-03-2013 04:10 AM
Is this normal? ArKiTeCkT Engine, Exhaust, Transmission 3 10-29-2012 03:54 AM
Is it normal to see a .... Mango22 BRZ First-Gen (2012+) — General Topics 10 10-12-2012 03:54 PM
