| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: 2016 Scion FRS Halo
Is the stock OEM Panasonic battery 55D23L rechargeable?
My battery is completely discharged from not driving my car often.
I'm looking at the stock FRS OEM battery and it says on the label, "Do not charge or use booster cables or adjust post connections without proper instruction and training". I thought wet/flooded batteries can be recharged. I looked everywhere and can not find an answer to this. Is there anyone out there whose stock OEM battery died on them and if so, what did you do? Have you tried recharging the battery and if so, what happened? Last edited by ghostzfh; 02-09-2017 at 10:54 PM. |
#2 |
Drives: 2014 BRZ
Yes of course you can charge them. Mine was dead when I bought the car on the lot. The dealer charged it awhile and it was good for three years.
Then I didn't drive the car for a few weeks and the battery got pretty low, so I put it onto a trickle charger/battery maintainer. It brought it back up and it is great now. |
| The Following User Says Thank You to T-Steve For This Useful Post: | wparsons (02-10-2017) |
#3 | |
#4 | |
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
| The Following 7 Users Say Thank You to Vracer111 For This Useful Post: | Cole (03-14-2017), funwheeldrive (03-14-2017), humfrz (02-10-2017), Plumbus (03-05-2020), Sportsguy83 (02-10-2017), tCsonfrs (05-12-2017), wparsons (02-10-2017) |
#5 |
It's just a disclaimer to protect against litigious assholes. Nothing special about the battery.
#6 | |
I Love custom Turbo kits
Drives: Limited BRZ
#7 |
Remove terminal cables and put on 2amp charge. Done
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#8 | |
Secondly, I'd suggest that you have your car's battery "load tested" at an auto shop ...... just to make sure it is up to speed (will hold a charge). The cautionary warning has been discussed..... (after messing with the battery, DO NOT wipe your hands on your pants or scratch your crotch) humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Ultramaroon (02-11-2017) |
#9 |
Panda Trueno
Drives: No twin now.
I love this forum.
| The Following User Says Thank You to Summerwolf For This Useful Post: | funwheeldrive (03-14-2017) |
#10 |
| The Following 2 Users Say Thank You to ghostzfh For This Useful Post: | humfrz (02-11-2017), Ultramaroon (02-11-2017) |
#11 |
Drives: 2013 Subaru BRZ
I charge mines every month. My daily trips are too short, doesn't charge the battery, so it's always weak.
#12 |
Drives: FR-S,GTI
I replaced my OEM battery with a AGM battery when the car was new. After about a year of sitting in the garage, I attempted to use the OEM battery for something else. It was COMPLETELY dead. Zero volts. I hooked it to a charger and it just plain would not take a charge.
Rather than throw it away, after all this was a brand new battery, this is what I did: I connected it in parallel to a bank of batteries I used for a UPS. The UPS is connected to a trickle charger. After about a month, I checked the battery in question and it was fully charged. It had come back from the dead. Two years later and it's still good (in my VW). |
#13 |
Mentat
Drives: 2013 Scion FRS 6MT
I got myself a smart charger. If i am going out of town for a week. I would pull my OE battery out and charge it. The car is 3 and half year old and it is still fine.
#14 |
Just curious, do you pull the battery because you can't park closely enough to an outlet? If so, I sincerely applaud your dedication.
| Tags |
| battery, oem, panasonic, rechargeable, stock |
| Specs of the STOCK battery?? | stevo_12v | Electronics | Audio | NAV | Infotainment | 74 | 10-31-2017 05:45 AM |
| How long does stock battery last without engine on? | jon2 | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 03-15-2015 10:58 PM |
| Warning to Canadian owners about stock battery | Suberman | CANADA | 46 | 03-02-2015 08:28 PM |
| Panasonic audio/nav switches itself off in the cold! | Suberman | Electronics | Audio | NAV | Infotainment | 0 | 12-05-2013 09:01 PM |
