Old 11-07-2014, 01:38 AM   #1
Snake
Drives: ADM Toyota 86 GT
75w85 Syn. or 75w90 semi syn
I'm looking to do a relatively cost effective oil change, however I'm not sure which way I should go.
I've got a couple of options but can't seem to find any which match up with the specs (without spending a fortune on Motul)
There is a 75w90 semi synthetic from Penrite which is GL-4/GL-5 compatible or numerous 75w85 full synthetic GL-4 oils.
Should I use the 75w85 full syn or the 75w90 semi syn?
I currently have Nulon 75w85 full syn GL-4 oil in the transmission and it seems to do OK. Will be changing the oil again as I track the car a fair bit so figure a transmission oil change per year will help keep the gearbox in good condition.
Snake is offline   Reply With Quote
Old 11-07-2014, 09:15 AM   #2
Shady195
Drives: '13 10 Series FRS #1203
While I often don't knock on people for saving money and not always going with the "Best" or buying some knockoff parts etc.
If you're concerned about spending $45 dollars for Motul or any other top quality gear oil that you shouldent have to change for a few years, maybe you should really think about about what it is you're wanting out of a vehicle.
Shady195 is offline   Reply With Quote
The Following User Says Thank You to Shady195 For This Useful Post:
Ferrari (11-07-2014)
Old 11-07-2014, 04:21 PM   #3
bluesubie
Drives: 2004 Subaru Forester 2.5XT
The OP is in Australia and would pay about $45 per liter for Motul.
http://bikeshop.com.au/collections/o...motul-gear-300
OP, IMO you'd be fine with a 75W-90 semi-syn at the track. PenRite Trans Gear is even thicker than Motul Gear 300 at 100C. I also don't think you'd gain anything by changing the gear oil out earlier than recommended.
-Dennis
bluesubie is offline   Reply With Quote
The Following User Says Thank You to bluesubie For This Useful Post:
Snake (11-08-2014)
Old 11-08-2014, 07:49 PM   #4
Snake
Thanks for your replies.
As above, Motul Gear 300 is about $45 a litre here vs around $15 for the other options. Penrite also comes in a 2.5ltr container so the difference between a Motul gear oil change and a Penrite is about $95 (as I have to buy 3ltrs of Motul). Australia - The land of double the price.
Doing around 8-10 track days a year I think changing the gear oil out more regularly will help to keep the gearbox in better condition than it would otherwise be in. Leaving it in for the full duration would worry me.
Motul Motylgear 75W90 ? (not Gear 300) manonastick Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 6 06-16-2014 05:40 PM
Motul Gear300 75W90 oil change interval? levinchow Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 04-09-2014 12:20 PM
Maxima 75w90 gear oil thought? Mike86 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 0 02-20-2014 11:21 PM
eneos en-gear 75w90 BadCompany235 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 01-03-2013 06:48 PM
