Old 12-30-2012, 07:20 PM   #1
Subie
Señor Member
Subie's Avatar
Drives: 2013 SSM DZE BRZ
BRZ Headunit/Radio Rattle
I had what I thought was a rattle from the trim surrounding the radio after having the GPS antenna TSB performed. However, after still experiencing a rattling noise after removing the radio trim and driving around, I noticed that the rattle is in fact coming from the radio faceplate. Is anyone else experiencing a similar issue? I'll contact the dealer about it soon but I'm not quite sure what they'll do about it since there's no obvious easy fix for it.
[ame="http://www.youtube.com/watch?v=RDnKA1cfGWU"]BRZ Radio Rattle - YouTube[/ame]
Subie is offline   Reply With Quote
Old 01-02-2013, 03:53 AM   #2
MrBodyMassage
Drives: 1994 Toyota MR2 Turbo, WRB BRZ Lim
I've got the same thing. It just started recently.
MrBodyMassage is offline   Reply With Quote
Old 01-04-2013, 02:36 AM   #3
lucius
Drives: Toyota 86 Pearl White
almost same issue here. But mine is the actual trim around the radio. Driving me insane!!. Packed it with foam the other day, still there. When I remove the trim the sound is gone. It's a plastic rubbing sound. Will scout the forums for solution.
lucius is offline   Reply With Quote
Old 01-05-2013, 10:23 PM   #4
Subie
Señor Member
Subie's Avatar
I pulled apart the radio trim today in an effort to duplicate the rattling noise while stationary. I was unable to definitively pinpoint the source of the noise but I was able to duplicate it which should be helpful in getting the dealer to resolve it. I uploaded a video to Youtube which features me duplicating the noise and have attached it to the first post. Make sure your volume is turned up.
Old 05-16-2014, 02:21 AM   #5
husker741
Drives: 2013 Whiteout Scion FR-S 6MT
Bumping this old thread instead of making a new one. My 2013 Bespoke HU is rattling like crazy. If i push down on the dash, like on the "leather" part of the hump that sits on the middle vents, it goes away. I hate rattles so this is driving me nuts. Anyone have a solution?
husker741 is offline   Reply With Quote
Old 05-16-2014, 09:42 AM   #6
Mikem53
Drives: FR-S 6MT
It must be karma because of your avatar..
I don't have this rattle yet.. Lol.. But I'm sure it's pending.. Or I can't hear it
Because of the other rattles..
Mikem53 is offline   Reply With Quote
The Following User Says Thank You to Mikem53 For This Useful Post:
Ozzman (05-16-2014)
Old 05-16-2014, 10:30 AM   #7
tobin
tobin's Avatar
Drives: '13 BRZ
I have the exact same noise on my BRZ with the nav unit. It seems to get worse as the outside temperatures get warmer. It disappears completely in sub 30º weather. I was going to have the dealer address it, this summer when I feel like leaving the car there. It's like a ticking/rattling noise. Removing the center vents does not fix it, but pushing down firmly on the top "hump" of the dash makes it go away.
tobin is offline   Reply With Quote
Old 05-16-2014, 08:48 PM   #8
husker741
Bump.
Old 06-02-2014, 06:52 PM   #9
CJB
Drives: 2013 BRZ Premium MT
Bump.
I have this issue as well and have a few ideas I'm trying out. Problem is it'll go away for a week and then come back, so it's really hard to narrow it down. I'll update here if I come up with a fix.
CJB is offline   Reply With Quote
The Following User Says Thank You to CJB For This Useful Post:
husker741 (06-03-2014)
Old 06-02-2015, 11:03 PM   #10
carma143
carma143's Avatar
Drives: Toyota Highlander; Subaru BRZ (SWP)
Bringing back old thread. Occurs in my 2013 BRZ Limited as well. I can push in the head unit and the rattle won't come back for various lengths of time. Typically occurs (but not limited to) when under 2000 rpm and strolling through my neighborhood. Forgot if it happens on the freeway as well. I'm over 60,000 mi so I no longer have a warranty under Subaru. I'll try to take the head unit out and see what all the fuss is about.
Edit: Ha! Just realized the last post was exactly one year ago.
carma143 is offline   Reply With Quote
Old 06-03-2015, 08:49 AM   #11
nivek111070
Drives: 2014 GB Scoobie BRZ
i don't have that yet, try putting some various pieces of Dynomat or rubber washers on contact points or possible contact points
nivek111070 is offline   Reply With Quote
brz, headunit, radio, rattle
FS: Stock Headunit Flawless22 Canada Classifieds 1 01-28-2013 01:07 AM
Rattle at base of radio trim/top of climate controls Subie Issues | Warranty | Recalls / TSB 4 12-17-2012 10:36 PM
WTB Besoke headunit jchall30 Audio/Visual, Electronics, Infotainment, NAV 1 09-26-2012 06:25 AM
Radio, Iphone?? Radio cuts out when surfing the web Fugazi Electronics | Audio | NAV | Infotainment 5 07-30-2012 12:24 PM
