Old 06-01-2014, 11:33 AM   #1
HRTROB
HRTROB's Avatar
Drives: Toyota 86
My oil smells like fuel
I was checking my oil level today and I noticed that the oil smelled like fuel. It was also light brownish-green in color. I don't think it's coolant because I'm not losing any. The fuel I am using is blue so that could explain the brownish-green color of the oil. It smells like the blowby oil/fuel I am catching i my Radium catch can.
When I checked the oil in my other car, which is also running the same brand oil and viscosity (5w30 synthetic) and has run roughly the same mileage (1,000 miles) it was medium to dark brown in color and smelled like regular used oil.
My mods are Vortech SC, DW 700cc injectors, DW65c fuel pump. According to my AEM wideband gauge, AFR drops to 10.7 then ends at 11.3 at redline when I go WOT. I also read that direct injection engines are notorious for fuel dillution in oil. What are your thoughts?
HRTROB is offline   Reply With Quote
Old 06-01-2014, 11:58 AM   #2
sato
sato's Avatar
Drives: Dodge Patitas
Send the oil in for analysis... Blackstone labs or such.
sato is offline   Reply With Quote
Old 06-01-2014, 12:01 PM   #3
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Wish I could, but we don't have a lab here that I can send the oil to for analysis.
Old 06-01-2014, 12:38 PM   #4
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
You mail it.
Sent from my SAMSUNG-SGH-I747 using Tapatalk
The Following User Says Thank You to Reaper For This Useful Post:
suaveflooder (06-01-2014)
Old 06-01-2014, 02:51 PM   #5
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Before you changed the oil, when was the last time you drove the car?
Some people let the car idle to somewhat warm before changing oil, which leads to fuel in oil. If you drive the car around, let it get full warmed up and then change the oil, the amount of fuel should lessen.
That's my experience with other cars, not so sure if it's true for this car.
Old 06-01-2014, 04:03 PM   #6
suaveflooder
Blue fuel? What fuel are you using? I know with E85 and Meth systems on the cobra because of the shere quantity being used, it gets in the oil faster. At least this was what was said on svtperformance. E85 guys always went with a touch thicker oil than stock and changed it more often. Then again, I don't personally have any experience with this, just what I read.
suaveflooder is offline   Reply With Quote
Old 06-01-2014, 04:07 PM   #7
HRTROB
HRTROB's Avatar
Drives: Toyota 86
I changed the oil in January of this year. Drove it to a shop about 10 minutes away. The oil currently has about 1,000 miles on it, including three track days.
Here's a photo of the oil from the dipstick. On the left is the sample from my other car (BMW M54 engine) and on the right is the one from my 86. Both oils are the same brand and viscosity and roughly the same mileage on them
Old 06-01-2014, 04:12 PM   #8
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Yep blue is the color of the fuel I'm using. Petron Blaze 100 RON pump gas, currently the highest octane fuel we have here. Took a photo of it when I changed my fuel pump:
Old 06-01-2014, 04:15 PM   #9
Reaper
Reaper's Avatar
Drives: violent
I pmed you. Get your oil tested.
Old 06-01-2014, 04:18 PM   #10
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Thanks. Kinda hard though due to my location. I'll have to find a courier that will be willing to ship an oil sample to the US.
Old 06-01-2014, 04:22 PM   #11
Reaper
Reaper's Avatar
Drives: violent
Some couriers will try and say oil samples are hazardous waste. Its not true.
Old 06-06-2014, 12:34 PM   #12
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
Stop sniffing your oil bro! Haha!
Tye300 is offline   Reply With Quote
The Following User Says Thank You to Tye300 For This Useful Post:
HRTROB (06-27-2014)
Old 06-06-2014, 01:12 PM   #13
SomeoneWhoIsntMe
Drives: 2013 Subaru BRZ
Is the car mostly used for short trips with no highway driving? usually if you drive the car for something like a half hour on the highway at temperature it'll evaporate and burn up all the fuel in your oil through the PCV. It's probably just making it's way down there in the blowby because you're running so pig ass rich.
SomeoneWhoIsntMe is offline   Reply With Quote
Old 06-27-2014, 01:56 AM   #14
HRTROB
HRTROB's Avatar
Drives: Toyota 86
I had my oil analyzed. As suspected, fuel was detected. No idea on how much though, the lab said they don't have the equipment to detect it.
Wear metals are low except for Silicon which is 90 ppm. Flashpoint less than 172C (341F) probably becuase of fuel dillution. No idea why TBN is at 11.1
Exhaust smells like a burnt marshmallow. disconnected Engine, Exhaust, Transmission 10 11-02-2014 12:32 PM
Car butt smells evan Northwest 15 01-13-2014 10:36 PM
Car interior smells like feet. dem00n Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 12 12-29-2013 02:07 PM
A/C smells after fuel pump replacement G.I.Choe Issues | Warranty | Recalls / TSB 5 12-18-2013 12:25 PM
Oil smells like fuel SloS13 Issues | Warranty | Recalls / TSB 21 03-10-2013 11:56 PM
