Old 07-30-2014, 07:41 PM   #1
Ocean-Grown 86
It was fun
Ocean-Grown 86's Avatar
Drives: Dirty FR-S
How to tighten handbrake?
Hi. I went drifting a few weeks ago and used the handbrake quite a bit. Towards the end of the day, the handbrake wasn't biting too well, which could also have been due to me overheating the rear brakes (I know I need to work on weight shifting). In any case, I have to pull it rather high just to get it to bite when parking. Does anyone know how to tighten it?
Thanks
Ocean-Grown 86 is offline   Reply With Quote
Old 07-30-2014, 08:32 PM   #2
Ubersuber
Drives: BRZ Pearl White
Sounds like you probably cooked the emergency brake shoes. If so then new shoes is the only effective cure. The emergency brake on these cars is a drum brake inside the rear hub. It's pretty powerful as I expect you discovered. Nobody reminds us to bed these shoes in as for the service brake because it isn't usually used for actually braking, except on cars like these! I recommend anyone with a car with separate brake linings for the emergency brake try to bed them in before flogging them. It is simple to do, just apply the emergency brake, on and off several times occasionally while driving, over a period of weeks. Bedding in the shoe lining early will protect it somewhat from overheating in sessions like the one you describe.
If you pay a mechanic to fix this then just fit new shoes. If you DYI and your labour isn't really important to you, i.e. you like doing the work or you don't mind spending the time, then as long as the brake shoe lining is not vitrified (looks mottled and a bit glass like) you can sometimes restore glazed brake lining with coarse emery cloth and then bed them in again after refitting. Trouble with that is if it doesn't work you do the brake job again and fit new shoes.
Ubersuber is offline   Reply With Quote
The Following User Says Thank You to Ubersuber For This Useful Post:
Ocean-Grown 86 (08-02-2014)
Old 07-31-2014, 02:22 AM   #3
Poodles
Drives: 2015 Series.Blue
Haven't had them in my hand to look, but if the shoes are anything like other cars with a mini-drum e-brake setup, they're small and thin meaning you've probably worn them out as they weren't designed for what you're doing...
The Following User Says Thank You to Poodles For This Useful Post:
Old 07-31-2014, 09:30 AM   #4
wparsons
wparsons's Avatar
The stock shoes are quite thin, only a few mm of friction material on them.
flickr
Old 07-31-2014, 01:07 PM   #5
D18
D18's Avatar
Drives: Scion FR-S (Hot Lava)
Slightly different issue, but does anyone know which way to rotate the emergency brake tension cog to tighten the E-Brake?
I recently replaced my rotors, and while I was struggling to get the rears off I played around with the E-Brake tension to try and make them easier to remove (I eventually succumbed to the sledge hammer method). Anyways, once I had everything back together, I clearly didn't have the tension set quite as tight as it was originally. I have to pull the e-brake right to the top to prevent the car from rolling on an incline, and even then I feel like its just holding.
D18 is offline   Reply With Quote
help please, how to tighten handbrake
Handbrake not working. MstrSHAKE Issues | Warranty | Recalls / TSB 44 01-20-2016 12:53 AM
How to keep DRL running even when the handbrake is on?? CX Cosmetic Modification (Interior/Exterior/Lighting) 25 03-08-2015 05:01 PM
Leather Handbrake Boot Repair himbo Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 12-12-2013 01:45 PM
BRZ complete red stitched handbrake BRZED Interior Parts (Incl. Lighting) 1 10-09-2013 04:28 PM
