Old 06-16-2014, 01:51 AM   #1
cpnslow
cpnslow's Avatar
Drives: 2013 Subaru BRZ Limited (WRB)
Rock in Brake... Is it Possible?
Last night, my car let out this horrible screeching sound while taking a tight turn at about 20 mph, as if metal were scraping on metal. I pulled over to the side of the road, creeped forward very slowly, and as I did, the screech would happen. Thinking it was something to do with the brakes, I pumped the pedal really hard about 5 times, and then it was gone. I did a full visual inspection and saw nothing out of the ordinary. Since then, I haven't heard the noise, and everything seems normal.
Did a quick search on YT and found the EXACT sound coming from a MazdaSpeed3. The owner described the same situation and same solution, and assumed it was a rock in between the rotor and heat shield. Is this possible? I'm hoping this is the case so I can drive on worry-free. Thanks!
[ame="https://www.youtube.com/watch?v=QTxZD9KpQC4"]Mazdaspeed 3 screeching sound. Rock in between brake pad and rotor? - YouTube[/ame]
My Build Thread: Nick's BRZ - "CPN SLOW"
My Car Photography: www.ngphotog.com
cpnslow is offline   Reply With Quote
Old 06-16-2014, 02:33 AM   #2
meeks
slide to unlock
meeks's Avatar
Drives: 2013 FR-S Raven Black
Yup. Happened a lot with my old civic. Just lift the car with a jack and try to free wheel all 4 to see where the noise comes from, inspect it. Usually rocks lodge themselves between the heat shield and the rotor.
meeks is offline   Reply With Quote
The Following User Says Thank You to meeks For This Useful Post:
cpnslow (06-17-2014)
Old 06-16-2014, 10:00 AM   #3
D_Thissen
D_Thissen's Avatar
Happened on my old tc. Got home, took off the front wheel and saw a small pebble wedged between the rotor and heat shield. Scared the $hit out of me! Lol
The Following User Says Thank You to D_Thissen For This Useful Post:
Old 06-16-2014, 01:29 PM   #4
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
I live on a dirt road (it's a rock road, really), and have had that happen with my trucks. Because I really don't like working on a truck, I just drive them until the noise stops.
dradernh is offline   Reply With Quote
The Following 2 Users Say Thank You to dradernh For This Useful Post:
cpnslow (06-17-2014), gramicci101 (06-16-2014)
Old 06-16-2014, 01:50 PM   #5
Andreas83
Andreas83's Avatar
It has happened with my BRZ a couple of times.
I normally stop the car, put it in reverse and then it falls out again.
But if you keep on driving it will be a bit more pain to remove.
Andreas83 is offline   Reply With Quote
The Following User Says Thank You to Andreas83 For This Useful Post:
Old 06-16-2014, 03:33 PM   #6
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
It is possible.
Old 06-16-2014, 03:49 PM   #7
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
it happened to me once the rock got stocked in the brake spindle (cover behind the rotors) and I thought the noise was coming from a ball bearing or something
glamcem is offline   Reply With Quote
The Following User Says Thank You to glamcem For This Useful Post:
Old 06-17-2014, 03:10 PM   #8
JRitt
JRitt's Avatar
Drives: 2012 BRZ Premium WRB 6MT
Yep...rock in brake is absolutely possible. One time running my old Z06 at Spring Mtn., I had one wedge between the caliper and the wheel...left a nasty gouge all the way down my pretty red caliper!
Essex Parts Services- AP Racing / Ferodo / Spiegler / Versodeck
Jeff Ritter|Mgr.- High Performance Division
www.essexparts.com
JRitt is offline   Reply With Quote
Old 06-17-2014, 04:19 PM   #9
GotBRZ1691
GotBRZ1691's Avatar
Drives: 2014 Subaru BRZ Limited 6smt
I got a rock wedge between my pad and rotor on my 07 wrx. Shit made such a terrible noise and I was 5 miles from my house on roads that had a speed limit max of 25. My ears hurt just thinking about it.
But yes totally possible.
GotBRZ1691 is offline   Reply With Quote
Old 06-17-2014, 05:15 PM   #10
wheelhaus
wheelhaus's Avatar
Happened to me as well. It was only wedged against the edge of the brake pad, so I pulled over, backed up about 2 feet, and then hopped out and found a half moon shaped pebble that was really hot and polished nice and smooth on one side.
Old 06-17-2014, 06:05 PM   #11
CSG Mike
CSG Mike's Avatar
Totally possible, and more common than you think!
Old 06-17-2014, 08:19 PM   #12
br_z1Lch
br_z1Lch's Avatar
Drives: 2013 BRZ(swp) Limited
Hah! I had this exact thing happen to me earlier this month, the night before I drove up to San Fran from LA! I jacked it up, took the tire off, pumped the brake with my hand a few times, and whatever it was went away. I took it to my buddy's shop the next day and they made sure nothing was wrong, and I went on my merry way.
I've never heard such a nasty (and scary) sound in my life!
br_z1Lch is offline   Reply With Quote
brake, noise, rock, screech, sound
Rock Hard Brake pedal in the middle of an autocross run... Jedi1 Tracking / Autocross / HPDE / Drifting 67 05-22-2018 03:40 PM
FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot CamryDS Interior Parts (Incl. Lighting) 0 06-24-2013 11:26 PM
Rock chips TheGuyWithTheFireStorm Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 1 05-23-2013 05:15 PM
FR-S(x2) available in Little Rock Moshpit37 Southeast 1 01-13-2013 11:08 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
