Old 08-21-2014, 01:35 AM   #1
FloridaFRSdriver
Drives: 2013 Whiteout FRS 6 Speed Manual
Opinions? Next Mod: Catless front pipe or lightweight aluminum driveshaft
See signature for current mods. This is my daily driver including frequent highway trips, so goal is stay reliable. That means stay NA, no footprint tuning only, sticking with 93 octane and giving weight reduction high priority for every mod (for example, I chose 17" x 8" RPF1s to drop 5lbs per corner instead of go larger).
I've been debating will be either a driveshaft shop lightweight aluminum driveshaft or a catless front pipe/ over pipe combo.
Since I've got a Borla cat back I'm considering the Borla cat delete front pipe / over pipe combo. (I have a Unichip to take advantage of the exhaust mods).
So... Driveshaft or catless front pipe... Which would you chose and why?
Long term plans include Speedfactory headers, lightweight flywheel and 4.56 final drive.
While I've become more or less immune to the noise of this vehicle (it's just plain noisy even without mods), I'd like to know if anyone here has the Borla catless front pipe? It's not resonated, does it rasp or drone? The Borla catback growls nicely at all revs and has almost zero drone, I'm wondering how it will interact with the catless front pipe.
2013 Whiteout FRS | 17"x8" Enkei RPF1s | Hotchkis TVS1 | Hotchkis Front End Links | Hotchkis Front Strut Tower Brace | Borla Cat-Back | K&N Drop-In Filter | Essex Sprint BBK, Stoptech SS brake lines, Perrin Master Cylinder Brace (the last few awaiting install)
FloridaFRSdriver is offline   Reply With Quote
Old 08-21-2014, 07:26 AM   #2
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
You will lose more weight from driveshaft than HFC. 12 lbs vs. 5.
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
The Following User Says Thank You to phobos512 For This Useful Post:
FloridaFRSdriver (08-21-2014)
♦♦♦ Driveshaft Shop ♦♦♦ Lightweight Aluminum and Carbon driveshafts. Manual or Auto FT-86 SpeedFactory Transmission and Driveline 101 11-26-2016 11:31 PM
FS: Driveshaft Shop (DSS) aluminum driveshaft (for AT only) $350 dp1 Transmission and Driveline 8 06-18-2014 05:16 PM
invida catless over pipe and front pipe bnb kingkai23 NY / NJ / CT / PA 0 03-14-2014 07:32 AM
PTUNING Weekly Special: Invidia Catless Front-pipe / Test pipe $229 INSTALLED! Patrick@Ptuning Engine, Exhaust, Bolt-Ons 3 10-01-2013 04:16 PM
Track pipe + catless front pipe diss7 Engine, Exhaust, Transmission 21 10-09-2012 02:10 AM
