Southern California SoCal
Old 04-09-2014, 08:01 PM   #1
mystic
mystic's Avatar
Drives: 2020 BRZ PP CWP
car beeping after engine shuts off
hey guys,
so today my car started giving me the beeping warning which usually happens when you leave your lights on. Three times I've taken my car out today, and all three times after turning off the engine the sound starts. There's nothing that's left on in the car, I don't know if this is just a sensor gone bad? When I close the door it goes away obviously. Anybody else experience this? Or am I stupid and have something on, or pressed that I don't know about that can cause this?
Thanks!
mystic is offline   Reply With Quote
Old 04-09-2014, 08:02 PM   #2
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
if you hit the engine start/off button after you open your door it'll beep i believe. car off w/o door closed before opening door = should be no beep
asdf is offline   Reply With Quote
Old 04-09-2014, 08:08 PM   #3
KSMatic
RSX Guru, BRZ Novice
KSMatic's Avatar
Drives: #91776
It may be still detecting the key fob? Do you have a spare somewhere?
KSMatic is offline   Reply With Quote
Old 04-09-2014, 08:10 PM   #4
mystic
mystic's Avatar
yeah I have a spare at home, I could give that one a try when I'm off work
Old 04-09-2014, 08:11 PM   #5
mystic
mystic's Avatar
hm..ironically, i might've had my door open all three times today? lol. I will do a quick test once I'm off work and see if that's the issue.
Old 04-09-2014, 09:13 PM   #6
JS + BRZ
Drives: 2010 MS3
did you steal something from the department store?
Old 04-09-2014, 10:27 PM   #7
Gumbate78
SoCal LA 86 Member
Gumbate78's Avatar
Drives: 2013 FR-S 6A\T Asphalt
I had the same experience some what before. The car beeps even there is no key in the ignition when I open the door or when I lock the door it still show on the dash board that a door is still open. I went to my dealer to have it checked/serviced and they discovered a broken fuse, they changed the broken fuse for free. My point is I want to know why/how it happened but they can't explain. Ever since I had no problems. Also I bought a cheap fuse checker from pep boys if ever it happens again. I hope this information help you.
SoCal LA 86 Club Member
Gumbate78 is offline   Reply With Quote
Old 04-09-2014, 10:42 PM   #8
stugray
Drives: 2013 GBS BRZ Limited
If your spare key is left in the car it will do this.
My daughter did me a "favor" and got in my car with the spare key to clean my windows.
Car was beeping for a few days before I figured out she left the spare key fob in the back seat....
Old 04-10-2014, 12:33 AM   #9
kkkirbyyy
kkkirbyyy's Avatar
Drives: 2015 STi and '93 Sentra Se-r
THIS. i also wondered when i first got my car and realized it was this scenario. lol.
kkkirbyyy is offline   Reply With Quote
Old 04-14-2014, 06:45 PM   #10
mystic
mystic's Avatar
haha
Old 04-14-2014, 06:47 PM   #11
mystic
mystic's Avatar
Thanks for all your help. Opening my door before hitting the start/stop button is the reason for the beep. However, the fuse situation is odd. I'll definitely have to stop by and pick one up from my local pep boys and keep in the car.
Beeping after ignition turns off.. chadstyle BRZ First-Gen (2012+) — General Topics 45 07-20-2020 02:53 PM
Beeping noise when shifting Lmiller40 Engine, Exhaust, Transmission 25 05-25-2014 03:41 PM
EasyGo system. Car remote starts then shuts off Unsustainable Electronics | Audio | NAV | Infotainment 3 06-27-2013 09:42 PM
Nürburgring shuts down.. Hanakuso Off-Topic Lounge [WARNING: NO POLITICS] 12 04-10-2013 03:17 PM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 07:50 AM
