Drives: brz 2013
vortech help
i found a diy but the pics r deleted
can anybody help me install this pulley i ordered give me a brief (or detailed) w.e u prefer on how to change the vortech pulley dont wanna mess things up i installed this kit myself so im sure i can insta this pulley just need a push in the right direction thanks a bunch guys |
#2 |
1) Buy a strap wrench
2) Remove tension from belt. Keep blower installed (so that way you don't need an extra hand). 3) Slip off current belt 4) Attach strap wrench secure tightly. 5) Using a flat head screw driver remover the warranty seal (this is not related to regular consumers, you still have a 1 year warranty). 6) Attach a (iirc)14mm socket / wrench to pulley bolt. Remove. Be careful not to drop the key. 7) Install new pulley with the original key. 8) Use blue locktite on 14mm bolt and tigthen to (iirc) 26ft/lb. 9) Loosen supercharger, remove required bolts and remove the current belt. Install matching belt or your new pulley. Reference the vortech belt guide for guidance on what belt to use. 10) Speak with your tuner and work out verifying your tune is capable of running the pulley you are using. Log and verify with your tuner that things are safe before driving any more.
When I grow up, I wanna be God. My flickr - Canibeat Local magazine scout Old Setup: Vortech Supercharged 360WHP/262WTQ @ 11.5psi My build thread - WTF happened to nelsmar's car thread |
| Vortech SC question | Cal3000 | Forced Induction | 13 | 08-01-2015 01:26 AM |
| FS: Used Vortech SC Kit | Sniper2606 | Engine, Exhaust, Bolt-Ons | 32 | 08-26-2013 10:55 PM |
| Used Vortech kit | skatery1989 | Engine, Exhaust, Bolt-Ons | 5 | 07-20-2013 09:01 AM |
| vortech hp | ft86me | Forced Induction | 1 | 05-28-2013 10:44 PM |
| NYC / LI Area Vortech | Foobar | NY / NJ / CT / PA | 30 | 05-08-2013 04:40 PM |
