Old 07-03-2014, 07:34 PM   #1
Raven604
Is this the right Pentosin mtf-2
Was just in Lordco auto parts in Maple Ridge here just outside Vancouver and noticed they had this stuff. It's the right stuff yes?
Sent from my SGH-I337M using Tapatalk
Raven604 is offline   Reply With Quote
Old 07-03-2014, 07:36 PM   #2
Raven604
Old 07-03-2014, 08:25 PM   #3
roddy
roddy's Avatar
Drives: '13 Ultramarine
That's the stuff. My bottles were/are grey rather than white, but the label says the right things.
Old 07-03-2014, 09:21 PM   #4
R2
Jesus that's pricy.
R2 is offline   Reply With Quote
Old 07-03-2014, 10:17 PM   #5
Raven604
I get 10% off at least >. >
Old 07-04-2014, 01:14 AM   #6
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Yup that's the tranny goodness gold.
Old 07-04-2014, 06:29 AM   #7
roddy
roddy's Avatar
Originally Posted by R2 View Post
Jesus that's pricy.
Sure is...but worth every penny. If you shop around, a better deal can be had. I've paid just over $20/liter locally.
Old 07-04-2014, 10:48 AM   #8
R2
I believe I recall you mentioning trying out many other oils before settling on Pentosin. Was one of them Redline MTL? I've got that in there now, and it feels ok, but I'm not overly sold on it yet. It seems like Pentosin is reviewed better, but not many have done the MTL route it seems.
Old 07-05-2014, 07:35 AM   #9
roddy
roddy's Avatar
I haven't tried a full fill with MTL...only a couple of blends. The 1st one was MTL/Honda MTF (the thinner one). That was just an experiment to see how the transmission would act with a thinner than stock fluid. I used that blend because that's what I had on the shelf at the time. This worked much better for the 1-2 shift, but once warmed up, there was a slight catch on the 2-3 shift.
The 2nd one was 1L MTL and 1.3L MT90 (I believe I said 1.3L MTL/1L MT90 in another post, but I checked my records, and that was incorrect). This one worked pretty good...almost as good as Pentosin except for the 1-2 shift when cold (still far better than the stock fill). I drive my car year 'round in Canada, and the outside temp had to be well below freezing before the 1-2 shift got miserable.
Redline has recently changed the viscosity rating on the MTL. I'm not sure if there is any actual difference in the fluid, but the stuff I bought last summer was 70W80. More recent bottles (and now the website) list it as 75W80 (same as Pentosin).
Old 07-05-2014, 02:59 PM   #10
R2
I replaced the fluid in January which let me directly compare stock to MTL in the cold. We had a couple of -30C days right after and the MTL was definitely lighter feeling and shifted easier, but I don't know if I'd say it was "better" feeling or not - the notchiness was still there. The 1-2 shift did not improve drastically either, even up to about 0C I was often "locked out" of that shift. Part of my issue is that for a lot of my driving, the engine, let alone the transmission, doesn't warm up completely when the ambient is below ~-5C. Simply because my drive to work is less than 15min. Longer drives did see the transmission working much better.
Now that it's summer, I'm almost thinking that I prefer the feel of stock, but it's hard to tell. I don't doubt that the MTL is a better oil, especially for winter, but I'm curious about Pentosin and will likely make the effort to try it out next time.
Old 07-05-2014, 08:06 PM   #11
Rocket.BRZ
Drives: 2010 WRX (sold) 2013 brz
Get some
MT90 gl-4 with 1 quart of Lightweight Shock Proof .
I've tried pentosin in this car. This cocktail is much much better.
Rocket.BRZ is offline   Reply With Quote
Old 07-05-2014, 08:41 PM   #12
unsurety
aeiou
unsurety's Avatar
Drives: WRB BRZ
WOW, thank god I have a connect for parts hookup.
Still, no regrets about getting it.
Originally Posted by Shoebox View Post
For that price anyone could get a c6z and have money for a simple heads cam package and make a bunch more power and have a superior handling car. This seems overpriced to say the least. "Have it your way" is basically offering someone a massive dildo to shove up their ass BUT they have the option of choosing the method in which it is inserted....
unsurety is offline   Reply With Quote
Old 07-06-2014, 12:49 AM   #13
qqzj
Drives: MDX, Camry
The worst part of MTF change is that everything fluid has mixed reviews. Some say:
1. Motul is better
2. Pentosin is better
3. Redline is better
4. Amsoil is better
5. Stock is better
6. Mix is better
7. Ford's stuff is better.
Some say:
1. Motul is worse than stock
2. Pentosin is worse than stock
3. Redline is worse than stock
4. Amsoil is worse than stock
5. Stock is worse than all others.
The confusing opinion is the only thing that prevents me from an MTF change. Do not want my money and effort go down the drain.
qqzj is offline   Reply With Quote
The Following User Says Thank You to qqzj For This Useful Post:
Raven604 (07-06-2014)
Old 07-07-2014, 01:14 PM   #14
Dezoris
Dezoris's Avatar
1. Motul is better
4. Amsoil is better
5. Stock is better
6. Mix is better
Some say:
I keep saying this but there is a manufacturing variance in these transmissions. What works well in some transmissions does not work well in others. Unfortunately you won't get a straight answer.
If your trans is very resistant to shift 1st to 2nd to 3rd and you are in a colder area Pentosin is a VERY good option to test. If you are getting notchiness when warm or problems with 4-5 or 6th it probably won't do anything.
The Following 3 Users Say Thank You to Dezoris For This Useful Post:
OICU812 (07-08-2014), Prodigalson (07-27-2018), roddy (07-10-2014)
Pentosin MTF2 Calum Engine, Exhaust, Transmission 10 12-09-2014 07:43 PM
Pentosin MT and Redline UOA After Track Supercharged Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 45 10-01-2013 12:02 AM
FS: Zeta air tube, hks drop in, & Pentosin chappys4life Mid-Atlantic 14 05-24-2013 12:58 PM
Pentosin mtf2 and approaching hot climate bdanisi Engine, Exhaust, Transmission 1 04-20-2013 10:48 AM
Looking for Pentosin MTF-2 in Ontario? wtout86 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 3 12-26-2012 07:07 PM
