Old 09-13-2013, 07:18 AM   #1
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Question Will the factory head unit fit other cars?
Sorry if this has been covered. It seems like it would have been. I tried searching, but maybe I couldn't think of any effective keywords. Anyway...
Will the factory head unit fit in other cars? Particularly an '06 Corolla? I remember reading somewhere that the head unit is a weird size, so I'm wondering if I could buy a kit to make it fit my girlfriend's car. If not, then I'm wondering if it's small enough to fit in the Corolla's console. I can always rig up my own bracket if I have to, but if the FR-S unit is too big, then I guess I'm screwed.
I don't know if the '13 FR-S even had options for a head unit, but just in case, this is the one I have. If that affects anything.
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 09-13-2013, 08:34 AM   #2
Wyllliam
Wyllliam's Avatar
Drives: Toyota GT86
Hi Anthony,
Normalle it will fit in other toyota's.
The FRs and GT86 use a 2 DIN facepanel (dimensions are 200x100 mm)
These are the dimensions for the standard facepanel for all toyota's.
You need to check with the dealer if you need seperate brackets to install this in the corolla.
The problem is going to be the wireharness.
Every generation of audio has a different pin layout and sometimes even different connectors.
So you are going to need an adapter to install this headunit in your girlfriends car.
For some generations these are made by Toyota but you have to check this with your local dealer.
Wyllliam is offline   Reply With Quote
The Following 2 Users Say Thank You to Wyllliam For This Useful Post:
Anthony (09-13-2013), cowdog360 (03-11-2014)
Old 09-13-2013, 09:03 AM   #3
nalc
Drives: 13 BRZ Limited 6MT GBS
The twins do not have a dual-DIN head unit.
It's a dual DIN height but it's wider than a normal dual DIN.
DIN is 180mm x 50mm
dual DIN is 180mm x 100mm
Twins HU is more than that. I believe Wylliam is correct in that it's 200mm x 100mm.
That's why you need to use a dash kit with black plastic blanks on either side of the HU when you install an aftermarket double-DIN HU into the twins, because those are only 180x100mm.
nalc is offline   Reply With Quote
Old 09-13-2013, 09:31 AM   #4
Anthony
Weight Nazi
Anthony's Avatar
Apparently the Corolla is 215x110mm according to anonymous internet guy in post #6 here: http://www.corolland.com/forums/inde...olla-din-size/
Old 09-13-2013, 08:25 PM   #5
soundman98
ProCrastinationConsultant
soundman98's Avatar
thanks guys for inadvertently answering my question on the hu sizing! ideas of running dual single-din's are running through my head..
Old 09-14-2013, 12:15 AM   #6
Anthony
Weight Nazi
Anthony's Avatar
You won't do a CD player and a cassette player.
Old 09-14-2013, 02:51 PM   #7
Wyllliam
Wyllliam's Avatar
Drives: Toyota GT86
All European Toyota vehicles have an audioless cluster, this audioless cluster is made for 200x100 toyota aftermarket audio.
And i'm 100% sure of this because i'm a multimedia engineer at toyota europe.
The corolla was a global vehicle so this cluster must be available.
Old 09-14-2013, 03:41 PM   #8
soundman98
soundman98's Avatar
no, but i might do a premier deck below a flip-out vga screen to keep my carpc...
Old 09-15-2013, 12:30 AM   #9
Anthony
Weight Nazi
Anthony's Avatar
So are you saying that guy is probably wrong about his measurments?
That is not the reaction I was hoping to instigate.
Old 09-15-2013, 01:50 AM   #10
soundman98
soundman98's Avatar
eh, maybe a 8 track would be better. i hear it brings some of the classics to life!
Old 09-15-2013, 02:36 AM   #11
Anthony
Weight Nazi
Anthony's Avatar
Haha there you go.
Old 09-19-2013, 11:47 PM   #12
Wyllliam
Wyllliam's Avatar
Drives: Toyota GT86
Im not saying that the measurements are wrong. Im saying that there Will be an cluster available with the 200x100 dimension for the corolla
Sent from my Nokia Lumia 720 using Tapatalk
Old 09-20-2013, 12:51 AM   #13
Anthony
Weight Nazi
Anthony's Avatar
Oh, ok. Good. So what should I search for to find one?
Old 09-20-2013, 03:11 AM   #14
Wyllliam
Wyllliam's Avatar
Drives: Toyota GT86
The easiest way to find information like partnumber and cost is to go to the dealer.
Normally the partnumber should look like 55405-xxxxx
BRZ Head Unit RedRocket Audio/Visual, Electronics, Infotainment, NAV 2 06-25-2013 11:21 PM
[For Sale] Factory GTS Navi Head Unit DanVIIIVI Australia Classifieds 6 04-20-2013 06:32 AM
Factory head unit wiring help please. jabbajaw99 Electronics | Audio | NAV | Infotainment 2 03-24-2013 07:09 PM
head unit in GTA excited86 Electronics | Audio | NAV | Infotainment 1 06-18-2012 08:42 PM
