Old 09-03-2014, 05:17 PM   #1
mrk1
Drives: Sterling BRZ Ltd
Installing ID injectors
To anyone else who has installed ID injectors, did you find them to be about 1/2" taller then the stockers? A spacer and longer bolts really are easy but I just wanted to make sure I wasn't shipped the wrong parts. PN on the box checks out.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 09-03-2014, 05:18 PM   #2
gramicci101
Off Topic
You need a rubber mallet to properly seat them.
p.s., don't do this.
Old 09-03-2014, 05:19 PM   #3
crazyfrenchbiker
Hot Lava 6MT
crazyfrenchbiker's Avatar
Drives: Hot Lava FR-S
Mine came with spacers.
crazyfrenchbiker is offline   Reply With Quote
Old 09-03-2014, 05:25 PM   #4
Dipstik-sportech
Dipstik-sportech's Avatar
1/2" nylon spacers, I think u can get them at home depot plus you'll need longer m8x1.25 bolts
Old 09-03-2014, 05:57 PM   #5
BirgeyT1
too soon jr
BirgeyT1's Avatar
Drives: 2014 Sterling Silver BRZ Limited
If they are ID725's or ID1000's then you will need spacers. The other sizes will not require them.
T1 Race Development
ID Injector Dynamics
BirgeyT1 is offline   Reply With Quote
Old 09-03-2014, 06:29 PM   #6
mrk1
nice, making spacers is no problem.
The Build Thread
Old 09-03-2014, 06:34 PM   #7
gramicci101
Off Topic
If you wanted to you could cut the mounting brackets in half and lengthen them.
Old 09-05-2014, 09:17 AM   #8
zkv476
zkv476's Avatar
Drives: 2014 SWP BRZ, MT
Yes I installed mine a week ago. They require 8mm (.315") tall spacers not 1/2" if you want to be precise . The injector body is 48mm vs the OEM 40mm. I turned a couple of them out of some 5/8" aluminum stock I had lying around. You'll also need to pick up four 25mm long M8 x 1.25 bolts.
Also make sure you take the old injector seals out of the intake manifold, I almost forgot myself. I only thought of this because you said it looked 1/2" high and those seals being in there with the added injector height would look about 1/2"
zkv476 is offline   Reply With Quote
E85 issues with injectors? CaptainSlow Software Tuning 66 07-31-2016 10:47 AM
Injectors installation kaybee123 Forced Induction 27 03-08-2016 09:26 PM
SprayItRacing (SiR) injectors vgi User/Vendor/Sponsor Reviews, Feedback, Comments 3 06-12-2014 09:12 AM
injectors and tuning? love 4 boost Software Tuning 8 11-09-2013 07:56 AM
