Old 02-04-2014, 11:02 AM   #1
NOHOME
Drives: RAVEN
Anyone else find 3rd gear redundant?
First car with a 6 speed box, and after a year and a half I have to say that the idea is kinda silly. The car has enough torque not to need 6 torque multiplying values on any kind of a regular basis.
For day to day driving, with shift points at 5500 rpm, the most effective shift pattern seems to be 1-2-4-6. the 2-4 shift has become so much the norm that I do it pretty much subconscious now.
Was wondering if anyone else had come to the same conclusion.
NOHOME is offline   Reply With Quote
Old 02-04-2014, 11:06 AM   #2
Mikem53
Drives: FR-S 6MT
The gears are close ratio for a reason.. Let's you keep the engines rpm's on full boil when you up shift.. You must be milking it for MPG's if you are skipping gears.
Mikem53 is offline   Reply With Quote
Old 02-04-2014, 11:21 AM   #3
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Day to day driving shifting at 5500 rpm??
Rayme is offline   Reply With Quote
The Following 19 Users Say Thank You to Rayme For This Useful Post:
Astroboy (02-18-2014), dave77 (02-06-2014), enthennd (02-04-2014), ericmpena (02-04-2014), GT 86 Brah (02-06-2014), Jaywest717 (02-04-2014), jonboy99 (02-04-2014), kevinnivek8877 (02-05-2014), kludger (02-05-2014), Marchy (02-04-2014), Mister (02-04-2014), Nasty Sausage (02-05-2014), PStaff716 (02-04-2014), schmearcampain (02-04-2014), SkAsphalt (02-04-2014), speedy07 (02-06-2014), strat61caster (02-04-2014), VesperLynn (02-05-2014), Wattage (02-04-2014)
Old 02-04-2014, 11:23 AM   #4
Hanni_0176
Hanni_0176's Avatar
Drives: 2013 Scion FR-S 10 Series MT
What is silly about a close ratio 6 speed transmission? Especially for a car with as narrow a powerband as ours...
Why buy a sports car if all you want to do is keep the car at the lowest cruising rpm's as possible? There are far more fuel efficient (econobox) cars on the market these days...
EDIT: After rereading the OP, I'm even more confused.
So what you are telling us, is that you are revving the car through the torque dip and then upshifting shortly after the revs get out of the torque dip (5500), skipping a gear in the proccess so that the revs drops down to cruising rpm's (around 2000)? And you do this from gears 2-4, and then again from gears 4-6? The fuck?
This makes no sense at all. For cruising, you should be upshifting between 2500-3300 rpm's, to the next gear (no skipping). For spirited driving or accelerating to merge/pass, you should be revving higher than 5500 rpm's (peak torque @6600 rpm's and peak horsepower @7000 rpm's) before upshifting to the next gear (no skipping).
The only time I could see skipping gears as being justified would be after merging/passing, at which point you'd skip to final gear (6th) to get into cruising rpm once you're at your desired speed/no longer accelerating. Even in this sort of situation though, I still run my car through the rest of the gears...
This thread... lol...
EDIT 2: My bad. Shifting from 2-4 and 4-6 at 5500 rpm's puts you right back at the beginning of the torque dip at 3000-ish rpm's, not 2000-ish.
Mods: K&N Air Filter - Open Flash Tablet (Stage 1 v1.55) - more to come!
Hanni_0176 is offline   Reply With Quote
The Following 10 Users Say Thank You to Hanni_0176 For This Useful Post:
jonboy99 (02-04-2014), kevinnivek8877 (02-05-2014), Luis_GT (02-04-2014), Marchy (02-04-2014), Ramster (02-04-2014), Rio (02-04-2014), strat61caster (02-04-2014), VesperLynn (02-05-2014), Wattage (02-04-2014), wu_dot_com (02-04-2014)
Old 02-04-2014, 11:33 AM   #5
Braces
Braces's Avatar
Drives: 17 Alfa Romeo 4C
There are other threads about the possible wear and tear on the gearbox from skip shifting. But I agree ... I also get "lazy" and will skip a gear or two on the upshift .... on those mundane work commutes. If I'm having fun with the car .... I never skip gears.
Braces is offline   Reply With Quote
Old 02-04-2014, 11:37 AM   #6
frslee
Just drive it
Drives: 13' FR-S
I'm pretty sure the Subaru/Toyota engineers have put down more than enough thoughts on every components of this car.
frslee is offline   Reply With Quote
Old 02-04-2014, 11:40 AM   #7
Canadian Greg
Drives: Black 2013 fr-s
I find the versatility of a six speed very appealing. Nothing silly about it. Yes you can skip gears if you are trying to save fuel and be lazy...
I rarely use the brakes when coming to a stop. I find third gear very useful in traffic.
And if you are shifting at 5500 rpm's you are aggressive to say the least.
Canadian Greg is offline   Reply With Quote
The Following User Says Thank You to Canadian Greg For This Useful Post:
Jond63 (02-04-2014)
Old 02-04-2014, 11:50 AM   #8
1Cor10:23
1Cor10:23's Avatar
Drives: '13 Whiteout FR-S (M/T)
I'm almost always in 3rd in residential areas (40-50KPH). I also find it's also the most satisfying gear to shift into, very little resistance ans super positive, straight through motion.
1Cor10:23 is offline   Reply With Quote
The Following 4 Users Say Thank You to 1Cor10:23 For This Useful Post:
Jond63 (02-04-2014), rcm47 (02-05-2014), SkAsphalt (02-04-2014), Wattage (02-04-2014)
Old 02-04-2014, 11:53 AM   #9
pasternak
Drives: Asphalt FR-S
I only use 3rd gear. I don't like the others.
pasternak is offline   Reply With Quote
The Following 11 Users Say Thank You to pasternak For This Useful Post:
Astroboy (02-18-2014), dave77 (02-06-2014), enthennd (02-04-2014), ftc~brz (02-05-2014), jonboy99 (02-04-2014), Nasty Sausage (02-05-2014), Rayme (02-04-2014), roddy (02-04-2014), schmearcampain (02-04-2014), SkAsphalt (02-04-2014), SpeedR (02-04-2014)
Old 02-04-2014, 02:11 PM   #10
Dezoris
Dezoris's Avatar
downshifting and engine braking dictates 3rd gear. Not going to dump into 2nd into a turn going 50MPH.
The Following 2 Users Say Thank You to Dezoris For This Useful Post:
boxer 2.5 (02-04-2014), SkAsphalt (02-04-2014)
Old 02-04-2014, 02:36 PM   #11
NOHOME
Drives: RAVEN
This...
I don't wear the helmet and fire-suit to work either, just doing the mindless commute thing 99% of the time. I live in Southern Ontario where curves and Unicorns have the same level of abundance.
I am not really an avid consumer of speedometer data, but 3000-3500 rpm seems to be the cruise spot for my travels and I can do it by sound rather than looking at a gauge; that's 4th at about 75-80 km/hr. The described shift points seem to keep me in that zone. Despite what the anti-fan boys say about the Twins, the car is not really torque challenged. You should try driving the 948cc Bugeye if you really want to know where a shift matters!
The Following User Says Thank You to NOHOME For This Useful Post:
wbradley (02-04-2014)
Old 02-04-2014, 03:33 PM   #12
wheelhaus
wheelhaus's Avatar
Speed limits in your area may not utilize 3rd gear much, but there's an entire world out there. I personally use 3rd a lot, occasionally i skip it, or another gear depending on how traffic is moving.
The gear spread at low rpm is almost always very close with a 6sp, sometimes the difference is only 200-300 RPM. Higher rpm is where the spread widens considerably, and is where the gear spacing is near perfect and the car really comes to life.
The car isn't torque challenged for commuting, you're correct. Between 3500-4500 rpm however, there is a noticeable sag in forward thrust and tighter gearing makes sense for the 4500+ range when you're actually enjoying the car.
Old 02-04-2014, 03:55 PM   #13
DarkSunrise
DarkSunrise's Avatar
I don't see a poll, but I use 3rd gear often, especially at the track.
2022 BRZ Build
2013 FR-S Build
Old 02-04-2014, 03:58 PM   #14
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Huh?
The Following 2 Users Say Thank You to dem00n For This Useful Post:
enthennd (02-04-2014), SkAsphalt (02-04-2014)
Top Gear Crashes Helicopter During Filming of "Top Gear Korea" Episode SteveH Other Vehicles & General Automotive Discussions 7 02-13-2013 01:08 AM
Reverse Gear not going into gear? MT joergasm Issues | Warranty | Recalls / TSB 22 11-29-2012 01:08 AM
No more 1st gear thump or 2nd gear notchiness kc4mne Scion FR-S / Toyota 86 GT86 General Forum 28 09-06-2012 09:39 PM
5th Gear and 6th Gear 0% throttle to 80% throttle gear crunch? kharn83 Issues | Warranty | Recalls / TSB 9 08-06-2012 08:44 PM
Reverse gear on the first and second gear side randytindoggy Scion FR-S / Toyota 86 GT86 General Forum 50 01-29-2012 02:21 PM
