Old 01-29-2014, 02:42 PM   #1
aakash
Drives: Asphalt FRS
How to Disconnect battery?!?!?!
Hey Guys,
I was looking around the site for a DIY or an explanation on how to disconnect the FRS's stock battery to install my new LED DRLs and Switchbacks. I have no idea how to disconnect it since this will be my first mod. I realize this may be much simpler than I am thinking it is, however Im still new to this.
Im thinking its just as simple as removing the wire with a socket that it attached to the battery. I do not need to remove the whole thing from the engine bay, just need to disconnect it.
Also, after the wires are disconnected, where would you guys set them aside within the engine bay?
Thanks So Much!
aakash is offline   Reply With Quote
Old 01-29-2014, 02:46 PM   #2
Diode Dynamics
Diode Dynamics's Avatar
You don't really need to disconnect the battery to install LED DRL's or switchbacks, but if you feel the need to, don't take your entire battery out, just disconnect the terminal
Feel free to call us if you need help with an installation: (314) 205-3033
Thanks!
Nick C.
John C.
Diode Dynamics
The Following User Says Thank You to Diode Dynamics For This Useful Post:
aakash (01-29-2014)
Old 01-29-2014, 02:47 PM   #3
Turbo95eg6
Turbo95eg6's Avatar
Drives: 2014 BRZ SWP LTD
Now that's customer service right thur.
The Following 3 Users Say Thank You to Turbo95eg6 For This Useful Post:
aakash (01-29-2014), eurominican (05-30-2014), hotpanda1 (02-21-2014)
Battery tray for Braille 21lb battery? lordtakuban Engine, Exhaust, Transmission 4 09-10-2013 09:55 AM
Issue after battery disconnect Audio related. Mako Issues | Warranty | Recalls / TSB 4 07-10-2013 10:29 PM
Disconnect battery for all LED installation? husker741 Cosmetic Modification (Interior/Exterior/Lighting) 3 03-30-2013 04:25 PM
TR-B1500 battery and billet battery tray install. mines13 DIY (Do-It-Yourself) Guides 8 12-07-2012 04:59 PM
Winter battery disconnect Skye Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 10-23-2012 01:28 AM
