Drives: 13 whiteout scion frs
Windows dont auto anymore
Went outside to warm car up since the windows were frosted and opened the door and noticed it wouldnt go down alittle like it normally does when you open the door i guess it was frozen shut. No big deal i thought. Go to roll down window and it wont auto do it plus passanger side button on driver side doesnt work andhe red that illuminates auto flashes on and off.. This cant be good
#2 | |
Now if there is just a way to program the car so it doesn't roll the windows down. Seems this happened because it did rain here yesterday then got to roughly 28* last night. It's been colder here before, but I guess the addition of moisture made them stick. @DanoFA20, you have this too? Don't know if you leave your FR-S outside. Also, what about you @speedracer38? EDIT: Also, page 223/224 of the manual states it too.
#3 |
Ill try i did bring them down but no luck with the auto down and the window wont go back up auto when i close the door and passanger window still wont go down from driver side
#4 |
IIRC, the "Auto" function will not work until the jam (the car thinks it's a jam) is cleared. So you have to push the switch all the way to make the window work at all. I also shut the car off, then hit the button twice without the clutch pressed (Basically lets you use everything, without the engine on. Can't remember the name off hand).
#5 |
Hail Magnet
1) lower window all the way, keep holding switch down for 5 seconds.
2) Raise window all the way, and hold switch up for 5 seconds. It sounds like your windows just need a reset. |
#6 |
Drives: 2015 CWP Subaru BRZ Series.Blue
It's fine don't worry. Just open the door and blast the heat for a bit you won't break the window if it doesn't roll down a few inches like normal.
#7 |
Wayward Member
Drives: Hot Lava 86
This is a concern I've been having as well. It's been really cold here in the mornings lately and pretty much every morning my car is completely frosted over. The windows can't do the auto roll down when you open the door because of the frost. I'm hoping this doesn't damage the mechanism.
#8 |
You say its not a problem but it seems to already be damaged 2 hours after the problem and there is still a problem. Flashing lights on button window sti wint auto up when door is shut so now its cracked a bit
#9 |
Are you able to move the windows at all with the switch? Try both toggle switches in the switch (half way and full).
#10 |
Driver side yes passenger side no only passenger side button works not auto though
#11 |
So do both lights blink? Have you tried resetting the window on the pass side by using the pass side switch?
#12 |
At work so will attempt later. How do u reset agaim?
#13 |
Drives: GT86
roll both windows down, then roll them fully up and hold switch for 10 seconds. Worked for me.
#14 |
Drives: Scion FRS
Mine did this today, it was below freezing this morning, but I park in a covered area so my car had no frost on it whatsoever, so I guess everyone should get used to doing the reset.
1. I had the car off, key in the on position. 2. Roll the Window Down 3 Hold the button down for an additional 5 seconds 4. Roll the Window Up 5. Hold the button up for an additional 5 seconds. |
| *Auto* Light from windows flash on driver's door | Walla Walla | Issues | Warranty | Recalls / TSB | 7 | 12-05-2013 12:09 PM |
| Does anybody use their blinker anymore? | Shagaliscious | Off-Topic Lounge [WARNING: NO POLITICS] | 51 | 11-20-2012 02:14 PM |
| Not taking orders for anymore? | Dorb | BRZ First-Gen (2012+) — General Topics | 22 | 11-08-2012 07:43 PM |
| I can't thank people's posts anymore?? | FRSjeff | Site Announcements / Questions / Issues | 2 | 08-09-2012 08:12 PM |
| question about tinted windows with auto dimming mirror... | Norcalmav23 | BRZ First-Gen (2012+) — General Topics | 13 | 04-06-2012 07:37 PM |
