Engineering Student
Drives: Scion FR-S 2015
Which brand of paint did you use for your headlight (Blackout)
For those who painted their headlight housing, can you please tell me the paint you used?
Brand Matte/Gloss/Semi/Gold/ Plastidip/Plastic Paint/Etc $
There’s no time to stop for gas, we’re already late
#2 |
Drives: Red BRZ
When you say "Painted headlights" - You are indicating the internal housing, correct? After baking?
Personally did this on my old car, not on the Subie yet, but: High-temp engine block paint in flat black. Three coats. And then a clear coat of matte finish. Only reason I went high-temp is projectors tend to get fairly warm, and down the road I didn't want any kind of flaking. |
| The Following User Says Thank You to BlackMonarch For This Useful Post: | hmong337 (12-23-2014) |
#3 |
Drives: 2013 Ultramarine FR-S
I used a duplicolor high temp Semi-Gloss Black. No Issue yet and its been a few months.
| The Following User Says Thank You to DustinS For This Useful Post: | hmong337 (12-23-2014) |
#4 |
Custom User Title
Drives: Asphalt FR-S MT
I think I used Krylon for plastics. Either that or Rustoleum.
#5 | |||
Engineering Student
Yes sorry, I thought housing automatically meant the internal of it. Smart to go with high temp. Quote:
I think of going semi gloss, I am hesitant Quote:
I have access to this in my local store.
#6 |
Drives: RX-7 / BRZ
Transparent black/smoke/vht looks really good as a 'black chrome' look.
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
#7 | |
The semi-gloss looks really good. I almost want to pick up another set and try gloss.
#8 |
Drives: RX-7 / BRZ
Prep work should be a given for any paint job.
Translucent paint is always going to be more sensative than solids. The blotchiness can be from quite a few senarios ranging from incorrect application to paint not being shaken up enough. Remember your spraying ontop of a smooth surface (with no tooth) applying paint to wet intially will cause it to clump up. However some rattle cans will just be patchy. Similar ecample would by if you ever attempt a very light smoke paint job on tailights with a rattle can. Due to the way the paint is sprayed you will have to due quite a few coats before the color will lay evenly. Warming the can's in some warm water or in the sun will due wonder for makeing them spray better.
#9 |
Engineering Student
Thanks for your inputs guys
#10 |
Engineering Student
Can you remove the paint done after 1-2 years
#11 |
No?
#12 |
Engineering Student
Paint cannot be removed once you apply it. I saw a video of people removing it using normal gasoline or something.. Its been a while I've seen the video. Maybe he was doing something else.
#13 |
Undercover Batman
Lacquer Thinner makes it come right off.
![]() "He who shall be last, shall be sideways and smiling." - Jeremy Clarkson |
#14 |
Engineering Student
Okay, thank you for that
| FR-S Headlight Reflector Blackout | DarrenDriven | DIY (Do-It-Yourself) Guides | 476 | 09-26-2020 03:39 PM |
| Modded Headlight+Taillight Swap (Blackout, carbon fiber) for your stocks! $200! | retrosmiths | Exterior Parts (Aero, Lighting, Etc.) | 16 | 04-15-2014 12:20 AM |
| Scion FRS Headlight Blackout Thread | womensecks | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 09-24-2013 09:13 PM |
| Headlight housing paint job | mariolefty1 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 06-04-2013 10:50 PM |
| Headlight blackout help | WolfsFang | NY / NJ / CT / PA | 10 | 03-24-2013 10:23 PM |
