Old 12-14-2013, 11:00 PM   #1
I<3Twisties
I<3Twisties's Avatar
Drives: SUBARWD
Recommended tire pressure for Thunderhill
So I'll be at Thunderhill this weekend and I'd like to get some idea of tire pressure there in this temperature.
I am running the Bridgestone S04 with stock suspension.
It'sgonna be fun!
I<3Twisties is offline   Reply With Quote
Old 12-15-2013, 05:34 PM   #2
icemang17
Drives: Scion FR-S/ Subaru BRZ
lots of variables in tire pressure...weather, alignment and driving style being the most important? Without getting into tire temp's I like to use the sidewall rollover test....if your hot pressures are too high you will notice the sidewall might only be half or less used....drop pressures until the sidewall is being worn, but not too far...only the tread part...not the actual sidewall itself....
I have seen heavy powerful cars that come in with literally the tire name scrubbed off...that is SCARY....
I ran my bone stock FRS with stock tire pressures....then I dropped them later in the day and grip improved....
icemang17 is offline   Reply With Quote
The Following User Says Thank You to icemang17 For This Useful Post:
I<3Twisties (12-15-2013)
Old 12-15-2013, 11:31 PM   #3
I<3Twisties
Drives: SUBARWD
That's a great tip. Thanks!
Old 12-20-2013, 02:50 AM   #4
RehabJeff86
RehabJeff86's Avatar
Drives: 2013 WhiteOut FR-S
different tires have different characteristic with different tire pressure, a general rule I would say keep all tires <38 psi hot. I run Rivals and its more stickier with 36 psi hot so I set 32 psi cold when I first arrived at the track and adjust after each session
2013 Scion FR-S whiteout
2012 Porsche Panamera S carbon grey
2008 Range Rover Sport SS black - sold
2004 BMW M3 alpine wies - sold
RehabJeff86 is offline   Reply With Quote
The Following User Says Thank You to RehabJeff86 For This Useful Post:
I<3Twisties (12-21-2013)
tire pressure mrnibbs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 10-18-2013 11:09 AM
Tire Pressure Fallen43 CANADA 2 10-12-2013 01:46 PM
what is your tire pressure? abling2 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-03-2013 11:49 AM
Recommended Tire Pressure for Aftermarket Wheels and Tires Chri5 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 05-15-2013 02:28 PM
What Hot Tire Pressure? gbgracer Tracking / Autocross / HPDE / Drifting 24 05-14-2013 06:47 AM
