| DIY (Do-It-Yourself) Guides For all DIYs. |
Drives: 2019 Mazda Miata RF
Rear fog wiring
Not really a guide, looking for input.
Currently I have my rear fog wired to the tail lights. I was thinking I'd like to have it on when the DRL's are on, as a sort of rear drl, for those times when it's not dark enough for the headlights to turn on, but I'd still rather not get rear ended. So, I was thinking of using the turn-on lead for the amp. In this case, the rear fog would be on, whenever the car is on, unless the radio is off? is the amp turn-on controlled by ignition, or radio? too much draw for the turn-on lead? I could use a relay if need be too, and tap into the amps power lead too. Any other sources of power in the back of the car? |
| How to use the OEM amp Wiring | RandomHero | Electronics | Audio | NAV | Infotainment | 258 | 07-04-2024 01:34 PM |
| Valenti rear fog alternate wiring | Gundark | Cosmetic Modification (Interior/Exterior/Lighting) | 87 | 09-14-2016 04:12 PM |
| Wiring BRZ rear fog light to only come on with front fogs | Scenic Driver | DIY (Do-It-Yourself) Guides | 4 | 09-12-2015 10:36 AM |
| Free-Rear bumper cover (entire rear facia) replaced after slight rear-end collision | n7011n | Exterior Parts (Aero, Lighting, Etc.) | 7 | 03-26-2014 05:46 AM |
| HELP WIRING MY ZETA REAR BUMPER BACKUP LIGHT | DealerFR-S | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 08-09-2013 06:55 AM |
