Old 09-10-2013, 01:20 AM   #1
DarkestBuddha
Drives: BRZ limited GBS
Which dry drop in air filter?
Hey guys just wondering what dry drop in filters do you guys use or suggest?
I think theres aFe, Avo, cosworth, apexi?
DarkestBuddha is offline   Reply With Quote
Old 09-10-2013, 01:28 AM   #2
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
dude they're all the same. Add about nil to anything as well...
Old 09-10-2013, 01:28 AM   #3
diss7
Drives: AE86, 2x GT86, TE27
TRD.
Because TRD.
diss7 is offline   Reply With Quote
The Following User Says Thank You to diss7 For This Useful Post:
ANTLAY (08-30-2016)
Old 09-10-2013, 01:54 AM   #4
EZWood
BAMF
EZWood's Avatar
I have apex, haven't had it long, but I installed it with my car on the dyno to get a tune so I can't give positive or negative comments. Any dry filter would be fine I think.
Old 09-10-2013, 01:57 AM   #5
cfusionpm
Drives: Firestorm 6MT Scion FR-S
K&N. Trusted since forever to produce a good and reliable product. I've had K&N filters on almost every car I've owned.
2013 Firestorm 6MT Scion FR-S
cfusionpm is offline   Reply With Quote
Old 09-10-2013, 09:14 AM   #6
BlackyRose
Drives: 2013 Raven FR-S
I called AFE a while ago and one of their top guys told me that they put just as much time if not more into research and development as anyone, including k and n. in addition, one of AFE orginal founders and leader of the company is a k and n defector. I don't have one, but everything I've read and seen all over the Internet leads me to believe that AFE is such a nice fit and finish with some actual engineering behind it. It's the most expensive one but in this case the money is probably well spent. The pro dry s allows less airflow than their wet filter, but it filters better so it's a slight trade off. I would pick up the AFE if I were you.
I'm going with the TRD prob as they use I believe k and n or aem to make their filters. Flow of an oiled filter with reliability of a dry filter because even if the engine somehow goes in the tank from the oil, the fact that its trd should take care if any repair costs. Again, this is hypothetical reasoning
BlackyRose is offline   Reply With Quote
Old 09-10-2013, 09:26 AM   #7
griffinnn
Drives: Red GT86 + Nav
On our UK owners forum there are dyno reults for most panel filters but the one we have found to give the best result is the HKS hybrid.
griffinnn is offline   Reply With Quote
Old 09-10-2013, 09:27 AM   #8
BlueDubbinTDI
I sound negative because you won't feel it on a butt dyno and airflow is always questionable. My PERRIN drop in doesn't even fit well in the intake box. Probably supports other mods but by itself I dont see it doing much at all.
Old 09-10-2013, 09:31 AM   #9
Kodename47
Kodename47's Avatar
Drives: UK GT86
That's not quite true, it's about the only one here that's been dyno tested before and after. My K&N performed as well as any other. I'd say it's hard to determine a real discernible difference between any panel filter.
.: Stealth 86 :.
Kodename 47 DJ:
Old 09-10-2013, 09:49 AM   #10
YMAA
Maximum puntential
YMAA's Avatar
Drives: 2013 DGM BRZ 6MT LTD
I went with the K&N because it's among the cheaper ones, it's a trusted brand, and I can't imagine there'd be much performance difference between the different filters.
YMAA is offline   Reply With Quote
The Following User Says Thank You to YMAA For This Useful Post:
Annahra (04-03-2014)
Old 09-10-2013, 09:54 AM   #11
Freude am Fahren
Drives: '13 DGM BRZ Limited/'14 Yamaha R6
Isn't K&N oiled only? The OP wants dry? I'm no expert on this stuff, so wouldn't K&N be out of the equation?
-XXR 527 18x8.75 +35
-Nameless 2.5" OP/FP Combo (Coming soon) & Axleback
-SBD 500X (Waiting on coating to install)
-Southbend SBD500X Clutch
Freude am Fahren is offline   Reply With Quote
Old 09-10-2013, 10:24 AM   #12
bfrank1972
Drives: 2013 FR-S Argento
AFE dry here, nice looking filter and looks like it's built to last a while. That's the benefit - you can just keep reusing them. Blow it off to clean and re-install. Any negligible HP gain is gravy.
Old 09-10-2013, 10:34 AM   #13
griffinnn
I stand corrected. There are dynos of the HKS filter making gains though
Old 09-10-2013, 10:40 AM   #14
Astroboy
Astroboy's Avatar
Drives: None
Afe for sure
Astroboy is offline   Reply With Quote
FS: NY aFe Dry drop-in filter, $35 snky_snky Engine, Exhaust, Bolt-Ons 16 08-20-2013 02:59 PM
Trd drop in filter Vino Engine, Exhaust, Bolt-Ons 3 04-14-2013 12:08 PM
best drop in air filter? Elgancho Engine, Exhaust, Transmission 15 04-10-2013 12:59 AM
Drop-in Filter huma Engine, Exhaust, Transmission 33 02-07-2013 03:47 AM
Drop In filter test! Stock, Apexi, No filter RallySport Direct Engine, Exhaust, Transmission 14 06-25-2012 03:40 PM
