Old 04-21-2017, 03:36 PM   #1
VVT4ME
VVT4ME's Avatar
Drives: 2014 Scion FR-S
Throwout bearing? Noise when blipping the throttle with the clutch in...
There's a quick metal ping/clank when quickly stabbing the throttle with the clutch in...noticed it when rev matching while driving the other day. Throw out bearing? Car only makes the noise with the clutch petal in. When moving, in neutral or in gear, there is no noise when blipping the throttle. There is also a quick audible noise when the car is running, not moving, but the clutch pedal is moved in and out. Car is bone stock, and not beat on. 24000 miles 2014. Anyone?
VVT4ME is offline   Reply With Quote
Old 04-21-2017, 05:28 PM   #2
Well, the TOB would be the usual suspect.
Old 04-21-2017, 05:47 PM   #3
MurderousPandas
MurderousPandas's Avatar
Drives: 2013 Scion FRS
Need more info. If it's the TOB, you should be able to hear it when coming to a stop or while stationary. When you push in the clutch, it will make an odd sound, but when you release the pedal, it will go back to normal. Replaced mine 10k ago
Sent from my HTC6535LVW using Tapatalk
MurderousPandas is offline   Reply With Quote
Old 04-21-2017, 07:12 PM   #4
VVT4ME
VVT4ME's Avatar
Problem is, I'm out of my 3 year/36k mile warranty :/ By TWO MONTHS.
Old 04-21-2017, 10:41 PM   #5
Edibrac
Edibrac's Avatar
Drives: 15 Series.Blue
You still have the 5 year/ 60k mile drivetrain warranty.
Edibrac is offline   Reply With Quote
Old 04-21-2017, 11:04 PM   #6
VVT4ME
VVT4ME's Avatar
....yea...I thought about that. But the TSB says it's only covered under the 3y/36k bumper to bumper...
Old 04-23-2017, 04:55 AM   #7
Simon86
Drives: 13 Scion Frs
I'm out of the main warranty period for mine by 3 months. Contacted them about it by 2 months and was told I was SOL for any sort of warranty because the release bearing is not covered under the extended warranty
Simon86 is offline   Reply With Quote
Throwout bearing going bad B-R-Z Engine, Exhaust, Transmission 40 09-08-2017 10:23 AM
Throwout bearing/clutch fork repair completion time ARTBRZ Issues | Warranty | Recalls / TSB 19 01-28-2017 10:28 AM
Throwout bearing? RavioliG Issues | Warranty | Recalls / TSB 3 10-31-2015 02:17 PM
act throwout bearing blown Engine, Exhaust, Transmission 0 08-30-2015 03:17 AM
Clutch Spring Removal & Throwout Bearing DemonRawr Issues | Warranty | Recalls / TSB 2 05-13-2015 09:08 PM
