Drives:
Upgraded cooling fans
I'm looking to track at least 6 timed next year, what's the best upgraded fans for the twins?
Sent from my SGH-M919 using Tapatalk 2 |
#2 |
| The Following User Says Thank You to Ultramaroon For This Useful Post: | continuecrushing (11-22-2014) |
#3 |
in orbe terrum non visi
Drives: violent
Factory fans pull more air than almost all aftermarket fans that fit. The biggest spal fans pull more air but require a customish shroud to be affective. FullBlown makes a kit. Buts if you're having problems fans are the last step. Oil cooler first. Then radiator. Then find a way to get the heat out of the engine bay. Then fans/shroud.
I have E85 where there isn't E85, that's my secret.
http://www.ft86club.com/forums/showt...t=reaper+build |
| The Following User Says Thank You to Reaper For This Useful Post: | misooscar (11-23-2014) |
#4 |
^^^this^^^ Oil cooler first and foremost.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | misooscar (11-23-2014) |
#5 |
Drives:
I have the Vortech 9 psi vishnu tune, perrin oil cooler, vented hood, but stock radiator and fans, I run in hot California tracks in the desert, can be 100 degree plus ambient...
Sent from my SM-N900T using Tapatalk |
#6 |
Drives:
Also , not the Vortech oil fed version 2
#7 |
Drives: violent
The fullblown radiator shroud and spal fans kit is pretty nice.
#8 |
Drives: 2013 Black FR-S
Save yourself the headache and just upgrade that tiny dinky Perrin oil cooler. Even people who are NA and track are realizing that 13 row is too small for the hotter months on the track here in CA.
Get a 15 row or 20 row setrab. You can buy just the core online and swap out your 13 row. Or you can but the Jackson Racing kit. We have tested time and again on a turbocharged engine and found that an aftermarket radiator like the koyo does not help the engine stay cooler vs the stock radiator. The radiator is not the weak link. Get those oil temps down and heat won't be an issue.
| Radiator Cooling Fans not getting power?? | John Rambo | Issues | Warranty | Recalls / TSB | 13 | 08-27-2014 11:17 PM |
| Stock wheels + Upgraded Tires vs. Wider wheels + upgraded tires | themajesticone | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 18 | 08-04-2014 03:49 PM |
| Any F1 fans here? | Shipwreck | Hawaii | 6 | 04-09-2013 03:56 PM |
| Any e30 fans here? | streetwaves | Other Vehicles & General Automotive Discussions | 83 | 12-12-2012 12:30 PM |
| Any UFC fans? | Enemies | Off-Topic Lounge [WARNING: NO POLITICS] | 13 | 06-26-2012 12:21 AM |
