STI MOTOR and TRANS mounts released.
![]() Pics of trans mount to follow shortly. makes a HUGE difference if you have headers and full exhaust and or close fitting exhaust parts. STi uses group-n durometer rubber but UNLIKE when you would add these to the WRX or STI, there is NO extra NVH. Yes simply revving the motor you see no more drastic engine movement. Installing these DOES Require raising the motor about 2 inches. We finally had to remove the rack bolts to get them in. Other wise its a half hour install. Myles |
| The Following 5 Users Say Thank You to Racecomp Engineering For This Useful Post: | Bu-Tang (05-11-2013), Calum (05-11-2013), LeeMaster (05-12-2013), mad_sb (05-11-2013), mokinbird87 (09-16-2015) |
#2 |
That Guy
Drives: 2013 asphalt FRS MT
Will you guys be selling these, Myles?
Sent from mission control |
#3 | |
Boosted
Drives: Not a supra....yet
#4 |
Drives: Sterling BRZ Ltd
Ive had a set of these in for a few weeks. Both motor and trans, absolutely love them. I found install pretty straight forward for a motor mount. Motor has to go up, I did not touch the steering rack.
With an aftermarket over pipe and catless front section the passenger side engine mount comes out over the rear of the cross member. The driver side mount came out the front of the cross member. Ive done a handful of engine mounts on STI's and would rather do the BRZ mounts given a choice.
#5 |
I wrote a bullet point type DIY on another thread about these. I did the install at a leisurely pace on the floor and found it straight forward. I guess it may depend on different people mechanical experience.
http://www.ft86club.com/forums/showthread.php?p=927895#post927895
#6 | |
Mw |
#7 |
#8 | |
WOW, never saw that thread ! (FAIL on my behalf) ![]() Myles |
#9 |
Pegasus White
Drives: 86
How much
Driving: Pegasus White Manual GTS 86.
#10 |
That Guy
| The Following User Says Thank You to Calum For This Useful Post: | DriftEightSix (05-12-2013) |
#11 |
Drives: Subaru BRZ Limited M/T
Anyone know what the difference is between the MT & AT tranny mounts. The engine mounts should be the same.
#12 |
Drives: Ultramarine FR-S 6MT
Will these mounts fit the frs? Question seems dumb, but I want to be sure.
#13 | |
Señor Member
Use google translate on this link HERE From what I can tell the STI parts are easier to get than the TRD outside of japan.
1974 TA22 Celica
2013 86 GT |
| Trans/Motor Mount question | DanoFA20 | Engine, Exhaust, Transmission | 5 | 03-02-2013 04:16 PM |
| PERRIN MOTOR MOUNTS FR-S & BRZ Just arrived PICTURES | gmookher | Engine, Exhaust, Transmission | 43 | 01-17-2013 04:30 PM |
| Trans/Diff Fluid. | DanoFA20 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 18 | 01-11-2013 04:11 PM |
| Buyer Beware: Motor Mounts | cobrabyte | Engine, Exhaust, Transmission | 5 | 01-04-2013 09:14 PM |
| How many hp more can the AT trans handle? | K-R | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 08-18-2012 02:21 PM |
