Drives: Black 2013 BRZ Limited Automatic
Torque on a Stock BRZ Head Unit
I am just looking around, and have been reading some of the threads on adding a backup camera. Would it be possible to add mirroring of an a phone and thus the Torque app in the same way?
Basically the cameras that are used have an RCA plug that leads into the head unit. Couldn't a splitter like this: [ame="http://www.amazon.com/Monoprice-Gold-Plated-Splitter-Adaptor/dp/B004C8I88W/ref=pd_bxgy_e_text_y"]Amazon.com: Monoprice Gold Plated RCA Plug to 2 RCA Jack Splitter Adaptor: Electronics[/ame] be used along with this usb powered HDMI converter: [ame="http://www.amazon.com/ViewHD-Universal-Composite-Converter-Standard/dp/B0080KN18K/ref=sr_1_3?ie=UTF8&qid=1368928605&sr=8-3&keywords=hdmi+to+component"]Amazon.com: ViewHD Universal HDMI to Composite / AV Video Converter, Support PAL / NTSC Standard TVs: Electronics[/ame] to allow phones / devices with an HDMI out to display on the stock head unit and still have a backup camera? I know it isn't as smooth or sleek as a brand new full android head unit, but I'm not after a better radio. I just want to be able to put all the gauges that Torque has on the screen where I can glance at them? Any thoughts? |
#2 |
Drives: '13 BRZ Ltd WRB
Not sure where you'd put that splitter. BRZ headunit doesn't have RCAs.
#3 |
It does via the backup camera input, just need the harness from svxdc or make your own. You would have to install a switch to fool the car into thinking you are in reverse so the screen comes on.
The resolution is fairly low though I don't know how good it would look. Also probably won't look too good with the parking lines. ![]() Might be better to just get a used Android phone to run it on. |
#4 |
I was referring to the adapter plug you get from svxdc or beatsonic. I completely forgot about the parking lines. I figured you'd have a switch to have the input be seen by the head unit though.
#5 |
I would just replace the HU with one that can run Torque natively. Even if you get the video feed into the stock unit, composite is a very crappy signal. It would look fuzzy.
#6 |
Yeah, it may not be a very good idea. Was just playing around with the thought. I don't even really listen to music much... I'm more of a talk radio guy.
I do like the torque app though, and I don't want to pay a few hundred bucks for it if I might be able to make it work on the stock head unit. I figure for 30 bucks it might be worth a shot. If anyone has any ideas or other suggestions I'm open to them. I'm going to put in the backup camera and I'll try it while I have the head unit out anyhow. |
| LNIB Stock FR-S Head Unit. | Chillyairplane | Audio/Visual, Electronics, Infotainment, NAV | 11 | 04-03-2013 09:18 PM |
| Stock head unit. | Flawless22 | Audio/Visual, Electronics, Infotainment, NAV | 1 | 03-27-2013 03:39 AM |
| Stock head unit | fitcious | Electronics | Audio | NAV | Infotainment | 1 | 01-16-2013 06:57 PM |
| [WA]: FS GTS Stock Head Unit | stevo_12v | Australia Classifieds | 6 | 01-15-2013 03:30 PM |
| question about stock F-RS head unit | mezdup | Electronics | Audio | NAV | Infotainment | 3 | 10-02-2012 01:15 PM |
