Old 04-19-2013, 07:39 PM   #1
iketiak
iketiak's Avatar
Drives: 2013 Toyota 86/Scion FRS
Thumbs up head unit swap speakers sound flat and muffled
I'm new to car audio I just installed the Kenwood 630wbt head unit and everything sounds flat. even with equalizer settings there is very little to no bass. Do I need to do a complete audio swap: speakers, amplifier, crossovers and subwoofer?
iketiak is offline   Reply With Quote
Old 04-19-2013, 07:43 PM   #2
brianlo622
brianlo622's Avatar
Drives: 2013 FR-S, raven
Your Kenwood should be providing more power than the stock head unit to the tweeter and midrange, and if you wired it properly, you should still be using that factory amp to power the door speakers. My system sounded better after the HU swap.
Which harness did you use? Im suspecting that somehow you are no longer using the factory amp to power the door speakers due to an incorrect harness.. got a pic?
Brian
悪魔のハチロク
2013 Scion FR-S, Raven
Current Mods: TRD Full Body Kit | TRD JDM Exhaust | SQ Audio by Simplicity in Sound
Stance Coilovers & LCA | TE37SL18x9.5PressedGraphite
brianlo622 is offline   Reply With Quote
The Following User Says Thank You to brianlo622 For This Useful Post:
iketiak (04-19-2013)
Old 04-19-2013, 08:04 PM   #3
iketiak
iketiak's Avatar
I'll try to provide a picture of the wiring tonight, thanks for responding! I also did not disconnect the battery during the installation, could I have fried something?
The Following User Says Thank You to iketiak For This Useful Post:
brianlo622 (04-19-2013)
Old 04-19-2013, 08:56 PM   #4
iketiak
iketiak's Avatar
Think everything is hooked up correctly maybe I just need new speakers.
Old 04-20-2013, 05:29 AM   #5
brianlo622
brianlo622's Avatar
Sorry for the late reply. Wiring wise looks fine, did you get this Kenwood to scion harness through crutchfield or something? (Since I dont see any crimping/crimp caps) Let me check my deck when I have a chance to see which color wires are for the front speakers and get back to you.
the OEM speakers are actually not bad at all especially if you are not using an external amp.
悪魔のハチロク
Old 04-20-2013, 09:48 AM   #6
iketiak
iketiak's Avatar
The connectors came with the head unit, everything was plug and play. After a full disconnect and reconnect everything seems to sound better...(maybe a loose plug) Could definitely feel the difference in sound quality!
BRZ Head Unit RedRocket Audio/Visual, Electronics, Infotainment, NAV 2 06-25-2013 11:21 PM
MD: BRZ Head Unit + Speakers itsfun Audio/Visual, Electronics, Infotainment, NAV 2 04-06-2013 10:03 PM
FS: Stock BRZ head unit (Sat, Nav, BT audio, etc) with amp & speakers Mach V Dan Audio/Visual, Electronics, Infotainment, NAV 20 02-18-2013 05:59 PM
New head unit/speakers Dkittrell Electronics | Audio | NAV | Infotainment 5 06-27-2012 04:01 PM
