Old 03-18-2013, 09:19 AM   #1
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
lug type help!?
i have XXR 530 18" and am looking into new lugs, but i have no idea what type of lugs i need. can any1 help me out?
lbroskee is offline   Reply With Quote
Old 03-18-2013, 09:53 AM   #2
leon78
leon78's Avatar
Drives: 13 Whiteout
http://www.ft86club.com/forums/forumdisplay.php?f=47
2013 Scion FR-S (Whiteout)
GunMetal 16x8+25 Enkei CompE_Cusco OCC_ Kartboy Crank Pulley_Kartboy TMM insert_Koni Yellows_RCE Springs_K&N Drop-In_Eibach FSB_J2 Catless FP_WhiteLine Camber Bolts_NameLess Track Pipe_RBF600_Ferodo DS2500_PTUNING Tuned.
Less parking more racing
leon78 is offline   Reply With Quote
Old 03-18-2013, 10:05 AM   #3
lbroskee
lbroskee's Avatar
I ment like what style fits since i know not all are universal. I know where to get them
Old 03-18-2013, 10:58 AM   #4
Beyer Subaru
Drives: 2013 BRZ SWP 6AT Ltd
12mm x 1.25. An easy way to search would be Suby lugs as the thread type has been the same for decades.
Beyer Subaru is offline   Reply With Quote
Old 03-18-2013, 11:09 AM   #5
lbroskee
lbroskee's Avatar
@Beyer Subaru obviously at this point i feel lik a complete moron, but this is what im asking about. I don't know how universal it is or if i need a dif style from stock
Old 03-18-2013, 11:11 AM   #6
Foobar
SLO NO MO
Foobar's Avatar
You want tapered ones (AKA "aftermarket").
But yeah, 12mm x 1.25 aftermarket/tapered is what you're looking for. Beyond that, it's all up to you (open/closed/anodized/locking key/etc).
The Following User Says Thank You to Foobar For This Useful Post:
lbroskee (03-18-2013)
Old 03-18-2013, 11:24 AM   #7
JT.
Drives: FRS
Yeah, hes right. 90% of all aftermarket wheels use tuner style lug nuts. And 1.25 is the correct thread.
If you want to have extra assurance look at NL motoring's website. they tell you what type of lug nut needed.
http://www.nlmotoring.com/XXR-530-Wh.../53088102n.htm
JT. is offline   Reply With Quote
The Following User Says Thank You to JT. For This Useful Post:
Old 03-18-2013, 11:34 AM   #8
lbroskee
lbroskee's Avatar
Awesome, thanks for the info guys
Old 03-18-2013, 12:37 PM   #9
CSG Mike
CSG Mike's Avatar
Some shameless promotion for the shop I drive for.
http://www.ft86club.com/forums/showthread.php?t=28792
Old 03-18-2013, 12:42 PM   #10
Beyer Subaru
I don't know if the others answered this or not. You want the conical/tapered version. I believe that would be a 60 degree taper.
Most all OEM and aftermarket Suby wheels will be of this design. The problem that you will run into with some aftermarket wheels is that the OEM lugs will make contact with the rotor before they are "tight" against the wheel.
Old 03-24-2013, 10:10 AM   #11
ILoveMyFR-S
ILoveMyFR-S's Avatar
Drives: FR-S Raven
Lug type help
What do you mean oem makes contact with the rotor? I'm running into some problems with my aftermarket rims.
ILoveMyFR-S is offline   Reply With Quote
Old 03-24-2013, 12:11 PM   #12
Beyer Subaru
Here is one example of some pics:
http://www.iwsti.com/forums/gr-tires...-wheels-2.html
This isn't exactly what I'm talking about but you can see that the aftermarket lug "seats" better because it has a larger tapered surface area vs the oem lug nut.
If the aftermarket wheel has a larger lug hole (tapered seat) then the oem nut might not seat properly.
Another good example. This time with aftermarket wheels:
http://forums.nasioc.com/forums/show....php?t=1485472
From our forums. Comparing an aftermarket nut to oem:
http://www.ft86club.com/forums/showthread.php?t=26685
Let me know if this helps clear it up for you.
Old 03-24-2013, 01:53 PM   #13
ILoveMyFR-S
Drives: FR-S Raven
Kinda. What I'm dealing with is the rotor rubbing, even with the oem wheels a slight rub. While driving with oem wheels no noise everything is normal, I jack up the car and spin oem wheels by hand I hear slight rubbing on the rotor.
Aftermarket rims. Wheel clearance is good its a 17 x7. Off set 42. Tires 225/45/17. The rotor rubbing with the aftermarket rims are a bit more, however when I drive it I can hear it rubbing as the car is moving. At a good volume.
Old 03-24-2013, 02:07 PM   #14
Beyer Subaru
Like pad on rotor rubbing?
I would suppose that if you were using improper lugs that didn't put proper torque on wheel to rotor to hub it could cause louder than usual rubbing.
To some degree there will always be a little bit of noise there in normal operation.
What type of connector is this? boredom.is.me Electronics | Audio | NAV | Infotainment 1 01-20-2013 01:28 PM
Oil type? orthojoe Tracking / Autocross / HPDE / Drifting 1 01-14-2013 05:11 AM
FRS/86/BRZ vs RSX Type S Maj3sty FR-S / BRZ vs.... 11 12-27-2012 06:17 PM
Eight-Six TRD vs FD2 Type-R suzuka FR-S / BRZ vs.... 47 08-19-2012 08:26 PM
What type off LSD you would like on the FT-86? Blokatos Engine, Exhaust, Transmission 43 02-17-2010 05:06 AM
