Old 03-05-2013, 10:35 PM   #1
Kai Uhl
Kai Uhl's Avatar
Turn signal problem
I recently switched my front turn signal bulbs for LED bulbs. As expected, I experienced hyper flashing. I then installed resistors to prevent the hyper flashing. When my headlights are off, the turn signals blink regularly (slowly flickers on and off) but when the headlights are turned on, the turn signal lights stay on and softly flicker on but never flicker off as opposed to flickering on then off on then off...
Does anyone know how to remedy my problem?
Kai Uhl is offline   Reply With Quote
Old 03-06-2013, 08:38 AM   #2
Cameronghanson
Drives: n/a
did you install just individual resistors or the blinker module? If it is just resistors then it sounds like an ecu thing your car is trying to work out and you probably need the module and if you already have the module then it's probably a bad one. Where did you get your LEDs from?
Cameronghanson is offline   Reply With Quote
Old 03-06-2013, 11:14 AM   #3
Lee358
Lee358's Avatar
Drives: nissan frontier, DGM MT BRZ
Brz or frs?
Lee358 is offline   Reply With Quote
Old 03-06-2013, 12:03 PM   #4
13 FR-S Veteran
13 FR-S Veteran's Avatar
Drives: 2013 FR-S (Raven Black)
Replace the Flasher Module, and don't mess around with resistors.
13 FR-S Veteran is offline   Reply With Quote
Old 03-06-2013, 12:06 PM   #5
abutterman
abutterman's Avatar
Drives: 2013 BRZ Limited - WRB, MT
yea the flasher module is the best bet since it's a direct replacement and takes like 30 seconds to put in. You can get one for like $10 or so and just remove the resistors
abutterman is offline   Reply With Quote
Old 03-06-2013, 12:23 PM   #6
Captain_Awesome_Pants
Captain_Awesome_Pants's Avatar
Drives: FR-S: Firestorm
This might not be the place to ask, but if I replace the fronts with LEDs but not the rear, can I still use the flasher replacement or do both front and back have to be LED before the swap?
Captain_Awesome_Pants is offline   Reply With Quote
Old 03-06-2013, 01:00 PM   #7
abutterman
abutterman's Avatar
yea you can still use the flasher. That's how i have it set up. LED's in the front and the standard bulbs in the back. Works like a charm
The Following User Says Thank You to abutterman For This Useful Post:
Captain_Awesome_Pants (03-06-2013)
Old 03-06-2013, 11:45 PM   #8
Kai Uhl
Kai Uhl's Avatar
Im not absolutely sure but I think I used 7440 bulbs (when I should have used 7443) which is the problem
Old 03-07-2013, 03:39 AM   #9
KayC
Drives: 2013 whiteout FRS 6mt
Not sure if this is the right place to ask, but for stock turn signal bulbs, it flashes by having the bulb go brighter -- dimmer-- brighter, (instead of mon--off--on) when the headlights are on. So isn't thee op's turn signal just doing what it does stock?
KayC is offline   Reply With Quote
Old 03-12-2013, 09:14 PM   #10
Kai Uhl
Kai Uhl's Avatar
I always thought when the headlights are on, the bulb flashes on the off on then off just like when the headlights are off. Or am I mistaken?
Old 03-12-2013, 09:16 PM   #11
Kai Uhl
Kai Uhl's Avatar
I replaced my bulbs with 7443 but am still having the same issue. Also, when the headlights are on, the bulb flashes really dim
Old 03-12-2013, 09:36 PM   #12
86 FRS
P i N O Y P R i D E
86 FRS's Avatar
Drives: 86 C7P MT
remove that resistor. and use a LED flasher module
itzzmeeken [My Journal]
86 FRS is offline   Reply With Quote
Old 03-21-2013, 11:23 AM   #13
scottmcphee
scottmcphee's Avatar
Drives: 06 Subaru Legacy
A flasher that works best for this application can be found in the vendor classified ads. Called 'TapTurn' solves the resistor problem and adds convenience signaling as well.
scottmcphee is offline   Reply With Quote
Is it possible to change turn signal to drl? Enraged21 Scion FR-S / Toyota 86 GT86 General Forum 4 02-22-2013 01:52 PM
Does 6k HID's Go well With the Turn Signal Switchbacks J-Money Cosmetic Modification (Interior/Exterior/Lighting) 17 01-29-2013 11:41 PM
Turn signal lights Brzer Cosmetic Modification (Interior/Exterior/Lighting) 9 10-18-2012 02:36 PM
Anyone seen these turn signal/drl less? djliquidsteele Cosmetic Modification (Interior/Exterior/Lighting) 7 07-15-2012 04:32 AM
Turn Signal Repeaters Ben_G Cosmetic Modification (Interior/Exterior/Lighting) 1 06-22-2012 11:26 PM
