Old 01-25-2013, 11:05 AM   #1
713_GT86
713_GT86's Avatar
Drives: 2015 Series Blue BRZ
Exclamation Suggested drop?..
Hello all,
Thinking of lowering the scion (springs and aftermarket gas shocks) setup on 18x9 SSR's SP-1's. What is the suggested drop height for this size of wheel, without having to deal with rubbing or fender issues? Thanks for the feedback. Any information helps.
-713_GT86-
713_GT86 is offline   Reply With Quote
Old 01-25-2013, 11:25 AM   #2
Xdragonxb0i
Drives: ex500r
1-2". Depends on how much tire tuck. Look for a hot lava FRS in car member journals. Its about 2" its so clean
Xdragonxb0i is offline   Reply With Quote
Old 01-25-2013, 12:12 PM   #3
713_GT86
713_GT86's Avatar
Their is no doubt in my mind of that lol...the last time I did a 2 in drop on a previous vehicle it settled in to about 2 1/2. The FR-S already sits low from factory. I think 2 even will be nice. I will need something that will settle in on just about 2 inches.
Old 01-25-2013, 12:14 PM   #4
Tim_Asphalt_FRS
Is it fast? No.
Tim_Asphalt_FRS's Avatar
Drives: 2013 Scion FR-S Manual-Asphalt
The Eibach Sportlines have the biggest drop as far as springs go, unless you want coilovers.
2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars}
[Wanted: Delicious Stg 2 tune, Bilstein struts]
Tim_Asphalt_FRS is offline   Reply With Quote
Old 01-25-2013, 12:24 PM   #5
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Yep, what Tim said. The sportlines will settle around 1.5 inches. You will be fine running those with an aftermarket damper like Koni. Here is the a guy on 18x9.5 +38 which is about the most aggressive you can get without messing with fenders.
http://www.ft86club.com/forums/showthread.php?t=26058
I would not suggest lowering the car past 1" without an aftermarket damper, as you risk blowing the OE dampers. If you plan to stick with the OE stuff, your best bet for lowering springs will be Eibach Pro-kit or RCE yellow springs.
If you are looking for 2", your only options would be coilovers.
Hope that helps!
-Yo
FT-86 SpeedFactory is offline   Reply With Quote
The Following 2 Users Say Thank You to FT-86 SpeedFactory For This Useful Post:
713_GT86 (01-25-2013), dun3 (01-25-2013)
Old 01-25-2013, 12:50 PM   #6
713_GT86
713_GT86's Avatar
Hope that helps!
-Yo
I planned on going with an aftermarket damper upon installation of the drop springs. 1.5'' looks very clean in the above link. This is ideal to how I would want mine to turn out. And yes! this does help. Thanks!.
FS: K&N Drop-in Filter DookDookDGM Engine, Exhaust, Bolt-Ons 4 01-19-2013 02:45 AM
how much of a drop? five-0 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 12-16-2012 10:10 PM
Who is going to buy the FRS DROP DROP Shop? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 1 10-18-2012 06:45 PM
Winter gas? MPG Drop Vukodlac Issues | Warranty | Recalls / TSB 12 09-17-2012 05:36 PM
TRD Drop in AF feldy Engine, Exhaust, Transmission 2 06-05-2012 09:40 PM
