Old 07-03-2012, 04:08 PM   #1
poudre
Drives: Silver Limited
Visor Warning Label Removal
FYI
They are NOT just a vinyl sticker that can be removed with a hairdryer.
They are painted on and come off in tiny bits when heated.
poudre is offline   Reply With Quote
Old 07-03-2012, 05:23 PM   #2
dstructo
Visor Warning Labels
Originally Posted by poudre View Post
FYI
I had some pieces of semi-gloss black adhesive vinyl cut to size, and just stuck it on top of the stickers. Any sign shop can do it in about 10 minutes, probably would charge you $10, and it actually looks just fine - blends in quite well - it's certainly a LOT better than staring at those damn white warning labels!
I don't know why they put those on the bottom side of the visors anyways....
-Paul
dstructo is offline   Reply With Quote
Old 07-03-2012, 06:00 PM   #3
OrbitalEllipses
Drives: Attitude
yo dawg, don't void your warranty...
Old 07-04-2012, 12:15 PM   #4
poudre
-Paul
It appears to me that overlaying the label (as you have done) with some kind of material is the only way to solve the problem.
Old 07-04-2012, 04:06 PM   #5
was385
Drives: MT WRB BRZ Limited, 2007 911s
Is this a joke? I seriously can't imagine how this would void the warranty.
was385 is offline   Reply With Quote
Old 07-04-2012, 04:21 PM   #6
OrbitalEllipses
Drives: Attitude
The labels, man! The labels!
Old 07-04-2012, 07:34 PM   #7
Jared0934
Jared0934's Avatar
Drives: Strawberry Pie
Wow, I picked at this sticker today and yeah that shits on there nice... If anyone figures out a clean way to remove it post that ish up
Jared0934 is offline   Reply With Quote
Old 07-04-2012, 07:37 PM   #8
#87
I usually post drunk
#87's Avatar
I heard you don't like stickers so we made a sticker to cover your sticker so you only see the sticker when you hide the sticker.
#87 is offline   Reply With Quote
The Following 3 Users Say Thank You to #87 For This Useful Post:
Bonburner (07-07-2012), jstans84 (09-18-2012), stanm (07-09-2012)
Old 07-04-2012, 07:47 PM   #9
ragingSPAM
Photojournalist
ragingSPAM's Avatar
Drives: Firestorm FR-S, EG8 civic
^^ LOL...that is freakin hillarious
ragingSPAM is offline   Reply With Quote
Old 07-04-2012, 08:25 PM   #10
poudre
"Goof Off" will easily remove the labels; HOWEVER, it leaves enough white residue (which I could not remove) to make the side of the visor, which had the sticker, a shade of grey.
FYI. Rubbing alcohol, gas, kerosene, and mineral spirits will NOT remove the labels.
Now, off to deal with this new issue!
Old 07-05-2012, 03:26 PM   #11
poudre
The Continuing Saga
Sprayed about 4 layers of Plasti Dip over the whole side of the sunvisor with the grey patches. It covered the grey and looked great; HOWEVER, when dry, the Plasti Dip rubs off easily with your finger and would take no wear what-so-ever.
Coated the Plasti Dip with 4 coats of satin polyurethane and now have to wait to see if that improves the durability of the Plasti Dip.
Will post the results.
Old 07-06-2012, 03:44 PM   #12
Khyron686
Drives: 2011 Outlander XLS, 2013 FR-S Blue
AHHAHAH I did it last night as well. Sticker off, but the side is way more washed out than the untouched side. Rub alc no dice, goof off worked but wrecked it.
I'm going to order a replacement (hopefully without a sticker) or have it wrapped up in fabric.
Khyron686 is offline   Reply With Quote
Old 07-06-2012, 03:55 PM   #13
Proud of BOXER
Drives: 74 Toyota Celica ST
For those who removed their sunvisors, is the wiring there for the illuminated sunvisors on non-illuminated (i.e. BRZ premium/FRS) cars?
Proud of BOXER is offline   Reply With Quote
Old 07-06-2012, 03:57 PM   #14
White64Goat
Sounds to me like someone needs to design some stickers that have either FT86 or BRZ on them that will apply over the factory stickers. You might want to contact a company called "Streamline Design" and see if they can't whip up something for you. They did a bunch of things for the PT Cruisers when they came out.
Exhaust tip removal Draco-REX Cosmetic Modification (Interior/Exterior/Lighting) 97 05-27-2017 05:50 PM
Hate those ugly visor warnings? avusblue Cosmetic Modification (Interior/Exterior/Lighting) 28 12-17-2014 03:16 PM
Limited Sun Visor Removal poudre BRZ First-Gen (2012+) — General Topics 7 07-08-2012 03:49 PM
FR-S Badge Removal skoodge Cosmetic Modification (Interior/Exterior/Lighting) 0 05-31-2012 12:46 AM
N1 Spec Visor Sticker GodSays Scion FR-S / Toyota 86 GT86 General Forum 13 03-04-2012 03:22 PM
