Old 12-06-2012, 05:21 PM   #1
subaruferrucci
Drives: FR-s
brake pump at idle rmp drop?
So i was noticing today that if my car is at idle and i pump the brakes a few times (3 or more times) that the car almost stalls then the RMP goes back up to 1k rmp for a min then settles back down to normal idle levels.
anyone have this happen to them?
I have a light weight pulley and full header back exhaust
subaruferrucci is offline   Reply With Quote
Old 12-07-2012, 02:07 AM   #2
bryan
bryan's Avatar
Drives: Lots of Toyotas
I just tried this earlier today and my car exhibits the same symptom!
I pulled into the garage and while at idle, I pumped the brakes several times. The engine RPMs dropped below 500 and then returned back to idle. I couldn't get the engine to completely stall though, no matter how many times I pumped the brakes.
It's disconcerting but hopefully won't be an issue or anything more serious.
bryan is offline   Reply With Quote
Old 12-07-2012, 11:38 AM   #3
subaruferrucci
Drives: FR-s
I am curious if they put to big of brake booster in the car. Uses to much vacuum and robs air from the intake.
I have a friend that says when he is racing it feels like he is running out of vacuum pressure during his autox runs
Old 12-07-2012, 11:49 AM   #4
Mac1235
Mac1235's Avatar
RPM RPM RPM RPM You called it RMP several times, it hurt.
Mac1235 is offline   Reply With Quote
Old 12-07-2012, 01:31 PM   #5
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Normal. Every car I've ever owned with a vacuum brake booster will see an idle dip if the brake is pumped quickly. You're just messing with the vacuum in the intake when you do that which distorts the MAP readings. Don't worry about it. There's no need to rapidly pump the brake pedal at idle.
The Following User Says Thank You to Draco-REX For This Useful Post:
gmookher (12-07-2012)
Old 12-07-2012, 01:51 PM   #6
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
so this would explain the phenomenon of idle dropping to 500 when i come to a quick stop then? maybe?
Freeman is offline   Reply With Quote
Old 12-07-2012, 01:59 PM   #7
Rayme
The Answer
Rayme's Avatar
Drives: Mazda 2
Stop doing it and it won't happen.
Rayme is offline   Reply With Quote
Old 12-07-2012, 03:53 PM   #8
Draco-REX
Corner Junkie
Draco-REX's Avatar
That is a separate issue. The ECU expects the MAP readings it gets when the throttle closes. Pumping a vacuum-boosted diaphram behind the throttle plate is not expected. If your idle drops when coming to a stop, that's been documented as an ECU/AVCS issue.
Saw this post and had to do this:
This man walks into the doctor's office and says, "Doc, my arm hurts when I do this!"
So the doctor replies,
Freeman (12-07-2012)
Old 12-07-2012, 04:45 PM   #9
subaruferrucci
Drives: FR-s
never had a car almost stall its self out after pumping the brake at idle. sound labored but not almost stall like that. and it also happens when i am just coasting to a stop while slowing with the brake then go to a full stop and the RPM dorp
Max NA HP on pump gas as of now? jadewbj Engine, Exhaust, Transmission 128 02-17-2016 10:28 AM
AC pump turning on and off BRZY Issues | Warranty | Recalls / TSB 3 11-26-2012 04:17 PM
Reported idle-drop and crickets - got turned away empower-auto Issues | Warranty | Recalls / TSB 11 10-21-2012 12:36 PM
Start-Up Idle Drop (VIDEO) MidnightMonkey Issues | Warranty | Recalls / TSB 18 10-02-2012 02:54 AM
Be careful at the pump with E15 Thunderchicken Scion FR-S / Toyota 86 GT86 General Forum 9 08-10-2012 11:33 PM
