Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 01-05-2022, 10:58 AM   #1
sds
Drives: '22 BRZ Limited 6MT
Engine/Trans mounts
Does anyone know if mounts from the 2013-2020 are compatible with 2022+ cars? Am looking specifically at the STI transmission mount, but potentially also at STI engine mounts.
sds is offline   Reply With Quote
Old 01-05-2022, 11:16 AM   #2
MMoore4545
Drives: 2022 BRZ
https://www.perrin.com/shop/vehicle/...ar=2022&page=1
Per Perrin's updated shop shows the Rear shifter bushing and engine mount kit as compatible across generations. Dunno about the OEM parts but it looks like it should be close/the same for those two at least.
MMoore4545 is offline   Reply With Quote
Old 01-05-2022, 11:53 AM   #3
dragoontwo
dragoontwo's Avatar
Drives: 22 BRZ limited
The rear trans mount and shifter stay bushing are the exact same. The engine mounts changed, but not sure about compatibility.
Old 01-05-2022, 01:00 PM   #4
sds
Thank you both! I'll order the STI trans mount then and can be a guinea pig
The Following 4 Users Say Thank You to sds For This Useful Post:
kaesu (01-06-2022), Midnightsky (01-05-2022), MMoore4545 (01-05-2022), RippedManiac (01-05-2022)
Old 01-05-2022, 09:17 PM   #5
RippedManiac
Jedi
Drives: Pikachu BRZ
If this works out it basically confirms ezpz 2.4 swap to 1st gen chassis.
RippedManiac is offline   Reply With Quote
Old 01-05-2022, 09:37 PM   #6
Poogchomp
Poogchomp's Avatar
Drives: Chevrolet Ram 250
Physical work, yes. Wiring, maybe.
Poogchomp is offline   Reply With Quote
Old 01-05-2022, 09:49 PM   #7
ForeverCar
Drives: 2022 BRZ and some other cars
It might take me awhile before getting to them. I ordered STi engine mounts and will report back if they fit once my shop can get me in.
ForeverCar is offline   Reply With Quote
The Following User Says Thank You to ForeverCar For This Useful Post:
kaesu (01-06-2022)
Old 01-06-2022, 12:28 AM   #8
kaesu
Drives: 22 BRZ
I was just thinking about this the other day. Not sure if it's just me but the mounts feel softer than the ones from the previous generation
kaesu is offline   Reply With Quote
Old 01-06-2022, 02:35 AM   #9
PNW Shaggy
PNW Shaggy's Avatar
Drives: '22 WRB BRZ / Prev. '17 WRB BRZ PP
I have a set of the STI engine mounts I was going to put on my Gen 1, but ended up returning to stock before I did for trade-in. Looking at the parts diagram Gen 1 and 2 have different part numbers (41020CC000 [2022] vs 41022CA000 [2017]). The prior Gen mounts also have locator block on the rear bolt where as, at least in the diagram, the Gen 2 mounts do not. *Edit: The Gen 1 STI mounts also have this block
If I have time this weekend, I could jack up the car and poke around, but I'm not expecting these mounts to work on a Gen 2.
**Double edit: AVO Turboworld used their same trans bushing insert for 2016+ manual trans on a Gen 2. Whiteline offers something similar
PNW Shaggy is offline   Reply With Quote
Old 01-06-2022, 11:11 AM   #10
dragoontwo
dragoontwo's Avatar
I am under the car already today, and I have all 3 STI mounts sitting around....
Also, the front subframe looks to be compatible with the longer steering rack bolts as well.
Old 01-06-2022, 11:12 AM   #11
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
I was honestly thinking the same thing. Maybe it’s the same stiffness but with the extra torque and grip? The drivetrain feels looser to me.
Old 01-06-2022, 11:17 AM   #12
dragoontwo
dragoontwo's Avatar
The trans mount is the exact same, but they changed to a liquid filled engine mount.
The Following 4 Users Say Thank You to dragoontwo For This Useful Post:
DocWalt (01-06-2022), kaesu (01-07-2022), sds (01-06-2022), Yoshoobaroo (01-06-2022)
Old 01-06-2022, 02:37 PM   #13
dragoontwo
dragoontwo's Avatar
Engine mounts are a bit different. They removed the rear mount riser and have a flat flange.
Good news everybody! I modified my STI mounts so they fit. I'm on a lunchbreak and not finished yet. I'll come back with a bit more detail.
The Following 6 Users Say Thank You to dragoontwo For This Useful Post:
ForeverCar (01-06-2022), kaesu (01-07-2022), PNW Shaggy (01-07-2022), Racecomp Engineering (01-06-2022), sds (01-06-2022), Yoshoobaroo (01-06-2022)
Old 01-06-2022, 05:52 PM   #14
dragoontwo
dragoontwo's Avatar
Gratuitous stock vs STI trans mount shot. STI on the right.
Engine mount stuff.
Stock 22 on the right.
What I chose to do is to run a unibit down the support until it separated from the mount, leaving the support washer on the other side intact.
I did this because I suck at using a hacksaw, and no good way to hold it for a cutoff wheel.
I went ahead and used a M10 washer so that it sits flat against the block.
Installed**
The subframe mounting stud for the STI mount is smaller than the stock 22 mount. You will need to source a pre 22 nut P/N: 902380011
The engine appears to sit at the same height as the stock mounts. i haven't had a chance to take it on the road yet as one of the OP studs broke on removal.
The Following 7 Users Say Thank You to dragoontwo For This Useful Post:
DocWalt (01-07-2022), ForeverCar (01-06-2022), kaesu (01-07-2022), Midnightsky (01-12-2022), MMoore4545 (01-06-2022), PNW Shaggy (01-06-2022), Yoshoobaroo (01-06-2022)
Perrin Engine Mounts, Sideways Fab Trans mounts PresiO. Engine, Exhaust, Bolt-Ons 25 10-07-2021 07:25 PM
FS: Cusco Engine and Trans Mounts. FRSH86 Engine, Exhaust, Bolt-Ons 0 04-19-2020 01:48 AM
Engine/ trans mounts Jmonty Northwest 4 02-13-2018 01:06 AM
what trans and diff mounts to get Pho20 Engine, Exhaust, Transmission 10 09-13-2017 10:56 AM
STI engine/trans mounts xwd Want-To-Buy Requests 1 03-11-2014 12:00 PM
