Old 02-07-2024, 05:50 PM   #1
systemmotorsports
FT86Club Official Vendor
systemmotorsports's Avatar
Drives: 86!
CAE Shifter for Gen-1 + Gen-2 GR86
Just landed, looking at this is a piece of art!
Shown is the Aluminum Uncoat with Delrin POM White shift knob. Can't wait to get these on the car this week! The quality and welds of these are second to none, very excited.
SYSTEM MOTORSPORTS
Top Distributor for Rays Engineering / Volk / Advan / BBS / Work / SSR, & More!
www.systemmotorsports.com
thomson@systemmotorsports.com / sales@systemmotorsports.com
Follow us on Instagram! / OUR '22 GR86 BUILD THREAD
systemmotorsports is offline   Reply With Quote
Old 02-08-2024, 06:56 AM   #2
endless_pain
Pissin off regressives
endless_pain's Avatar
Drives: They have engines.
Is this a second gen of the shifter? I don't see how this one would fit.
endless_pain is offline   Reply With Quote
Old 02-08-2024, 08:21 AM   #3
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
You know there's a dedicated place for ads right?
Old 02-08-2024, 05:37 PM   #4
Jdmjunkie
Drives: Scion FR-S 10 Series
Is it going to fit the first gen without modifying the center console?
Jdmjunkie is offline   Reply With Quote
Old 02-08-2024, 06:34 PM   #5
PulsarBeeerz
Drives: JRSC BRZ SOLD
I believe the "old" IRP shifters were um inspired by CAE shifter.
From CAE's site.
PulsarBeeerz is offline   Reply With Quote
Old 02-08-2024, 06:48 PM   #6
RedReplicant
Drives: None
AAF is bringing their shifter to our chassis too, it'll be out soon.
https://advancedautofab.com/p/aaf-bm...e-shift-shaft/
RedReplicant is offline   Reply With Quote
Old 02-08-2024, 08:13 PM   #7
blsfrs
blsfrs's Avatar
Drives: 2013 frs base
Gulp! $1245. My stock one is good for now.
Old 02-09-2024, 06:41 PM   #8
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
From CAE's site.
I mean, there is only so many ways you can design a shifter with that pivot design and lockout. It’s by far not exclusive to CAE.
It is purty though.
Old 02-21-2024, 10:33 AM   #9
kevaughan
kevaughan's Avatar
Drives: BMW E30, 2014 FR-S
This is great news. I keep hearing that the IPR shifter has a lot of issues regarding rattles and NVH. Obviously that's a non-issue if my car was a full race car but less than ideal for daily driving. So, I'm keeping my eye out on this one.
kevaughan is offline   Reply With Quote
Old 02-21-2024, 05:16 PM   #10
ZC6_STi
ZC6_STi's Avatar
Drives: 2015 Subaru BRZ Series.Blue #709
Just received mine straight from CAE a couple of days ago with the aluminum shifter and blue shift knob. Took 4-5 days to deliver after placing my order. Total cost: $917.39. It would been over $1k+ for the Black anodized coating
Overall, the quality and craftsmanship in person are amazing. I'm getting rid of my STi short shifter for a direct feel, so I chose this route for street/track.
The photo from "systemmotorsports" is to be a WRX/STi version.
I've noticed one thing that has changed compared to the old version for the BRZ/GR86/GT86 platform is the nut bolt on top where the reverse linkage located is removed and now is directly onto the shifter frame. I'm guessing it is to help avoid cutting into the center console for clearance on Gen 2?
I'm not so sure about the Gen 1 for cutting into the center console as I'm still waiting for a couple of other parts before installing this. Sorry for the sideway photo since I don't post much on the forum.
ZC6_STi is offline   Reply With Quote
Old 02-21-2024, 06:07 PM   #11
Ohio Enthusiast
Drives: 2018 BRZ
Would be very nice if you don't need to cut the console for both generations. Please report back!
Old 02-21-2024, 06:26 PM   #12
ZC6_STi
ZC6_STi's Avatar
Will do! Unfortunately, after researching on the Gen 2 market. You need to cut into your console for fitment. This was posted on the CAE website. I believe on another forum for the Gen 2 platform, a member posted that he needed to cut the console as well
Old 05-27-2024, 08:55 PM   #13
ZC6_STi
ZC6_STi's Avatar
Sorry, for the delay guys. But I finally got around to installing the shifter and here's the final result with the new revised CAE shifter for the Gen 1 with WC Lathe Werks Custom Shift Knob and Carbon Fiber Shift Plate Cover.
Unfortunately, as everyone is asking "Do you have to cut into the console? " and the answer is "Yes". There's no way of getting around it. The cut is underneath the shift cover as the "Reverse Mechanism" is interfering with the top portion of it when going into reverse, though it isn't exposed once the shift cover is back on. Another cut is about 1/2 inch located on top of the center console. I used the toothpaste mark method to minimize the cut, and slowly smooth the edges for fitment for the center console.
The installation was easy, but it took 3 hours since the Shifter Lever Retainer was a hassle to remove without removing the Driveshaft. I had to remove the Front Pipe and unbolt the Transmission Mount & Driveshaft Centre Support to get enough clearance to remove the Shift Lever Retainer. With everything removed, it was roughly about 4.11 lbs compared to the CAE Shifter which is 2.92 lbs. Also, I would recommend lubricating between the "Floor Shift Control Shaft" and "Pin + Plate Washer" and covering with a dust boot to reduce any dust getting between those parts. Maintenance on the CAE Shifter is lubricating all the moving parts of the shifter 2x every year.
Overall, compared to an STi Short Shifter. It is "night & day", and it felt completely raw. There is less throw about 55-60% from OEM, according to the CAE Website compared to the STi Short Shifter being 20% from OEM less throw, and the CAE Shifter is much more precise and consistent. Since the shifter is taller, the travel distance between the steering wheel and the shifter takes less than a couple of seconds to get back on the wheel. Great for track enthusiasts. If you want precise shifting, this is the best bang for your buck. Great investment!
Old 05-28-2024, 08:27 AM   #14
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
Thanks for sharing! Where did you get the CF plate from ?
autoracer86 is offline   Reply With Quote
CravenSpeed Product Launch: GR86 Short Shifter Logan@CravenSpeed Announcements, Contests, Giveaways 8 08-07-2024 12:22 PM
FS: 2022+ BRZ/GR86 BilletWorkz Short Shifter slimfit Transmission and Driveline 4 08-24-2023 07:59 PM
San Diego: 2022 GR86 OEM Premium GR86 Rims GRime86 Wheels and Tires 3 12-10-2022 04:52 PM
GR86 In R7 of the Toyota Gazoo Racing GT Cup + GR86 coming to Grand Turismo Sport Blighty GR86 General Topics (2nd Gen 2022+ Toyota 86) 28 07-18-2021 03:38 PM
FS: Stock Short-Throw Shifter, Springs, and Rear Shifter Bushing bergy Transmission and Driveline 8 10-20-2016 09:57 PM
