Old 08-21-2019, 09:42 AM   #1
skogs
Drives: GT86 2013
How much ATF should be changed at main service?
I'm taking my 2013 GT86 AT in for its 6-year main service at a dealership tomorrow. In the quote they specified 2L of auto transmission fluid. I asked them if that was correct, as it sounded very little compared to the 7.5L total capacity. They confirmed that it was standard procedure to change only 2L.
Does this sound right to you guys?
skogs is offline   Reply With Quote
Old 08-21-2019, 12:20 PM   #2
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
They are probably just doing a drain and fill, not a full flush with that little fluid
Old 08-21-2019, 04:42 PM   #3
Tristor
Tristor's Avatar
I'm not sure what is specified, but personally I'd want to do a full 7L, which is what I do each time I change my ATF. It is more work since you can only do about 2L at a time and must row the gears to get fluid exchange to occur. They can pressure flush it, but I advise against that as it can damage the internals. Since your car is 6 years old and is out of warranty, you should consider doing the service yourself at home. I made a thread in the DIY forum on how to do this, it's a bit time consuming but pretty straightforward.
Tristor is offline   Reply With Quote
The Following 2 Users Say Thank You to Tristor For This Useful Post:
ddevl_86 (03-07-2021), why? (08-25-2019)
Old 08-25-2019, 07:49 AM   #4
theadmiral976
Drives: WRB Subaru BRZ Limited 6MT
http://www.ft86club.com/forums/showthread.php?t=8374
Page 140-142 of the PDF linked above. 2L is spec for a standard drain and fill service.
theadmiral976 is offline   Reply With Quote
Old 08-26-2019, 10:56 AM   #5
86TOYO2k17
Drives: 2017 toyota 86
I think a 2L drain and fill every 15-20k miles would probably be fine. At 60-80k a full 7.5L drain and fill (but specifically not a flush) would be advised.
@ZionsWrath @theadmiral976
Old 08-26-2019, 12:43 PM   #6
ZionsWrath
Thanks
ZionsWrath's Avatar
Originally Posted by 86TOYO2k17 View Post
I think a 2L drain and fill every 15-20k miles would probably be fine. At 60-80k a full 7.5L flush would be advised.
3-4 drain and fills, NOT a flush
The Following 2 Users Say Thank You to ZionsWrath For This Useful Post:
theadmiral976 (08-27-2019), Tristor (08-26-2019)
Old 08-26-2019, 03:15 PM   #7
86TOYO2k17
True, if you want to be unnecessarily technical about it.
Old 08-27-2019, 08:24 PM   #8
theadmiral976
Except that being technical in this situation is entirely necessary. Flushing the transmission is used by many shops and other people in the industry to imply forcefully extracting transmission fluid followed by a complete fill. Some transmissions can handle this procedure, assuming it is done correctly. But there is plenty of evidence, anecdotal and systematic, that power flushing can lead to additional damage and even destruction of many transmissions.
In general, and especially for low mileage (under 200k) transmissions, the risk of sludge being left behind with just a drain and fill is way lower than the risk of damage to the transmission with a power/vacuum flush. Therefore, lots of shops and other professionals strongly recommend sequential drain and fills, either all at once or over time (say, 2 L once every 20-30k).
Old 08-27-2019, 08:45 PM   #9
86TOYO2k17
Definition of Flush - “cause (a liquid) to flow through something”
I am causing 7.5L (of ATF) to flow through my transmission in order to flush it.
Old 08-27-2019, 08:57 PM   #10
theadmiral976
You are correct when using Merriam-Webster and even probably in many other industries and professions. Unfortunately, the auto repair industry has co-opted that word to indicate use of a power/vacuum-assisted machine that (typically) hooks up to the transmission cooler lines. Lots of people assume that this is what is happening when you ask for a "transmission flush service." Since that service can harm many transmissions, it is important to clarify this for people, especially since many people use forums like this to learn about stuff. The last thing any of us want is for someone to harm their car because they misunderstood something that isn't entirely obvious (as it uses what amounts to an industry colloquialism).
The Following User Says Thank You to theadmiral976 For This Useful Post:
Old 08-27-2019, 09:06 PM   #11
86TOYO2k17
Ok corrected it.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
theadmiral976 (08-28-2019)
Old 02-18-2024, 01:14 PM   #12
RickyBobby
Drives: 2013 Firestorm FR-S AT
Necroing an old thread. I have ~50K miles on my FR-S in 11 years, runs great. Planning on changing the AT fluid at 60K.
I also had a 2014 Ford Escape that I changed, (3 x 4 qts drop and fill) the AT fluid (9 qts capacity) at 70K miles and planned to do it again at ~130K. I purchased 3 more gals on sale of https://shop.valvolineglobal.com/pro...smission-fluid
The Escape got totaled and we replaced it with a 2024 Hyundai Tucson.
I used the Valvoline Multi-Vehicle ATF in the Escape with no problems. According to its product spec sheet it is ok for all Scions. https://sharena21.springcm.com/Publi...0-ac162d889bd3
I know that the FR-S ATF capacity is 7.9 qts, and the shop manual states to do a 2 qts. drop and fill.
Has anyone that has done this got out more then 2 qts. a drop?
The attached excel Partial Drain calculator was posted on the Bob is the oil guy forum a few years ago. Partial Drain Helper.zip
If you plug in 7.9 qts in the Total Fluid box and 2 qts in the Partial Drain and Refill Amount box it calculates it would take 16 qts of new fluid to reach 90% new fluid. How accurate is this calculator???
RickyBobby is offline   Reply With Quote
Old 02-19-2024, 01:45 AM   #13
finch1750
finch1750's Avatar
The attached excel Partial Drain calculator was posted on the Bob is the oil guy forum a few years ago. Attachment 224007
I have only used 6-7qts max when doing drain and fill 3x for each change
RickyBobby (02-19-2024)
Old 02-19-2024, 07:09 AM   #14
RickyBobby
Thanks for the info. I have 12 qts of the Valvoline Multi-Vehicle ATF. I could do 5-6X drop and fills if you can get only ~2 qts out a drop.
Here's a screen shot of the partial drain helper:
Name:  Screenshot 2024-02-19 055818.jpg
The Following User Says Thank You to RickyBobby For This Useful Post:
Ohio Enthusiast (02-29-2024)
FRS main airbag G-Man Interior Parts (Incl. Lighting) 7 03-04-2019 10:04 PM
Any Scion / Toyota service techs here? Main Body ECU replacment question. boomslang Scion FR-S / Toyota 86 GT86 General Forum 4 08-30-2014 02:56 AM
summit point main 9-14 -9-15 subaruferrucci Tracking / Autocross / HPDE / Drifting 15 09-17-2013 06:48 AM
Summit Main 9/14-9/15 fredk Mid-Atlantic 2 09-02-2013 12:59 PM
WTB Main Body ECU Acree Interior Parts (Incl. Lighting) 2 03-05-2013 06:31 PM
