Old 08-06-2015, 05:11 PM   #1
tjohnson104
Drives: brz
sti steering rack bolts and bushings
I can not get the stock steering rack bushings out. Anybody have good ideas? I saw somebody use a C clamp but I do not that have. I am also trying to do the sti longer bolts and those I could not even get in. It feels like they want to cross thread, and so I put the stock ones back in. Anybody have a hard time with these as well?
tjohnson104 is offline   Reply With Quote
Old 08-06-2015, 05:29 PM   #2
GirlRepellent
GirlRepellent's Avatar
Drives: Evo X FE/FRS 10 Series
Cusco makes a tool to remove those. I used it when I did my STI steering rack bolts/bushings. Made the job so much easier.
Happy 86 day!
Part# 965 935 SST
http://www.cusco.co.jp/en/parts_prod...lease_ava.html
GirlRepellent is offline   Reply With Quote
Old 08-06-2015, 06:01 PM   #3
OkieSnuffBox
Drives: '23 BRZ Limited
And you can make a tool exactly like that for like $10 in parts from Lowe's/Home Depot.
Old 08-06-2015, 06:03 PM   #4
Createddeleted
Drives: 2014 BRZ - 2004 GLI
1.5" galvanized pipe nipple and a clamp will do it.
Createddeleted is offline   Reply With Quote
Old 08-06-2015, 07:59 PM   #5
tjohnson104
Drives: brz
okay that will cover the bushings, but any idea why the bolts wont go in? I dont want to tripe anything
Old 08-06-2015, 09:14 PM   #6
Panman
Panman's Avatar
Drives: 86 GTS
I put my STI bolts in at the same time as my Whiteline bushings. A little bit of "stiction" going in, but I made sure I cleaned the far end of the bolt holes (at the front end of the subframe holes) and it was fine - start by hand until I was sure it was on the thread then handtools till tight.
Panman is offline   Reply With Quote
Old 11-23-2023, 10:45 AM   #7
Jozy
Jozy's Avatar
Drives: 2015 Subaru Brz Limited
Do yall have the part number to the nut@ & bolts to do this mod? I called the dealer they had no clue what I was talking about.
Jozy is offline   Reply With Quote
Old 11-23-2023, 01:11 PM   #8
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
North American dealers won't have them since it's a JDM BRZ tS part.
You can order them from Japan Parts:
Bushings:
https://www.japanparts.com/parts/detail/?id=43136
Bolts, nuts & washers:
https://www.japanparts.com/parts/detail/?id=47821
The Following 2 Users Say Thank You to NLSP For This Useful Post:
norcalpb (11-24-2023), x808drifter (11-23-2023)
100% Solid Press Fit Steering Rack Bushings Carolina Dyno Brakes, Suspension, Chassis 9 04-17-2015 05:44 PM
Steering Rack Lockdown/Bushings Apex_BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 08-18-2014 02:01 PM
TiC steering rack bushings review mokinbird87 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 07-21-2014 01:43 PM
Solid Steering Rack Bushings (Press Fit) Carolina Dyno Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 12-03-2013 01:13 AM
GROUP BUY - TiC BRZ/FR-S steering rack bushings Turn in Concepts Groupbuys 186 03-19-2013 09:04 AM
